SOLVED: Issues w Octane 4.05 for C4D R19
3dphase
Hello.
I´ve some issues with Octane 4 in Cinema 4D R 19.
1. Rendering a sequence of frames in rendermanager ends after one frame although there are 50 frames to render (e.g.). There´s no error message. It simply stops rendering after finishing first frame (I alraedy came to 2nd or 3rd frame but then it stops as if renderjob were done).
2. Using denoiser function causes Cinema to crash completely after it had rendered first frame succussfully and should start denoising.
Error-message: "The plugin c4dOctane-R19.cdl64 has crashed. More information...."
These issues only appear in larger scenes. In small scenes both 1. and 2. work fine.
I´ve tried different older drivers - seems to be same issues even with older drivers.
Octane 4.05 | Cinema 4D Studio R19.068
Win10 Prof. 64 bit V 10.0.18363
i7 3930 6-Core, 2 x GTX 980Ti
Drivers: tried different from NVidia: 419.67, 431.60 up and newest.
Any help would be appreciated.
Edit: The good old and general problemsolver: Copy all. Close project. Paste all in new project. Fixed those issues.
mrom
Did you use any c4d shaders?
Copy paste to new project that means you have a problem with settings of rendering.
J.C
aoktar wrote:Copy paste to new project that means you have a problem with settings of rendering.
What settings could crash plugin?
System – Windows 11
Neither in common, there maybe a specific problem in their scene which conflicts with some settings.
rclassenphoto
i have the same problem , if i open some files and the scene loads the octane plugin is crashing.
i attached my Bug Report file
_BugReport.txt
(618.49 KiB) Downloaded 235 times
OK bugreport points that's a crash at renderer. Doesn't show what causes. You have to find it. It may be a bug or out of ram or vram. Watch render statistics during render
