OctaneRender™ 2020.1 XB1 [superseded by 2020.1 XB2]
linograndiotoy
I agree with Notiusweb.
Look at how Octane for Cinema deals with it. Sun position is associated with the rotation of a Directional light, which works perfectly imo.
TRRazor
I always thought, that Poser did this fantastically in it's native host application.
46788-poser-ch7-1-figure0704 (1).jpg (13.28 KiB) Viewed 9127 times
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
Zay
TRRazor wrote:I always thought, that Poser did this fantastically in it's native host application.
+1
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
osiosiosi
+1
mojave
GillesKontrol wrote:Any idea when network rendering is going to be a possibility again?
We will make available the slave build in one of the next releases.
GillesKontrol wrote: On the standalone I cannot get multipass rendering to render as well, it just gets stuck at the end of the first frame and doesn't move on to the next frame.
Do you have at least one device enabled for tonemapping or denoising in case you are using the denoiser in your scene?
GillesKontrol wrote: Also for some scenes, when RTX is off, the scene renders fine. When RTX is on, the frame comes out as completly black. They're all exported from the C4D 2020 Plugin.
Could you share any of the scenes you mention maybe via PM so we can reproduce this?
GillesKontrol
Any idea when that will be? I'd rather it not work sometimes now, but still have it then troubleshooting exported C4D scenes all the time.
It's an experimental build, so some things not working could be expected - so unless you guys had to remake it from scratch I don't see why it couldn't be included.
Yes, both with denoising on or off it still does not finish rendering the frame. All devices have tonemapping enabled and only one has denoising.
Will send it :).
tobywe
Hi, I was just asking on the Houdini plugin forum about the recommended workflow for using ACES and Juanjo suggested I enquire on this general release forum. Am I right in thinking that textures need to be pre-converted to ACES CG and I was also wondering about viewing the render in ACES space in the IPR. I'm still hazy on all the ins and outs but it would be great to know the best practice moving forward, if anyone can give guidance?
Many thanks,
Toby
itsallgoode9
tobywe wrote:Hi, I was just asking on the Houdini plugin forum about the recommended workflow for using ACES and Juanjo suggested I enquire on this general release forum. Am I right in thinking that textures need to be pre-converted to ACES CG and I was also wondering about viewing the render in ACES space in the IPR. I'm still hazy on all the ins and outs but it would be great to know the best practice moving forward, if anyone can give guidance?
Many thanks,
Toby
It would really be great to if OTOY would create, a step by step for correctly working with an ACES workflow in regards to Octane. I've looked into this a lot myself but ACES is new to me, as well, and I'm not clear whether tutorials from other render engines are directly applicable to Octane or if Octane has some Octane specific stuff, regarding ACES.
karl
Many thanks,
Toby
itsallgoode9 wrote:It would really be great to if OTOY would create, a step by step for correctly working with an ACES workflow in regards to Octane. I've looked into this a lot myself but ACES is new to me, as well, and I'm not clear whether tutorials from other render engines are directly applicable to Octane or if Octane has some Octane specific stuff, regarding ACES.
The current experimental build contains support for exporting renders in "ACES Image Container File Layout" format, which is an uncompressed 16-bit EXR file in the ACES2065-1 color space with some additional metadata. There is currently no support for any other ACES color spaces such as ACEScg, or ACES textures, or ACES interactive preview. It is likely all of these will be made available as a result of further color management work coming in a future 2020.1 experimental build - watch this space.
jayroth
karu wrote:The current experimental build contains support for exporting renders in "ACES Image Container File Layout" format, which is an uncompressed 16-bit EXR file in the ACES2065-1 color space with some additional metadata. There is currently no support for any other ACES color spaces such as ACEScg, or ACES textures, or ACES interactive preview. It is likely all of these will be made available as a result of further color management work coming in a future 2020.1 experimental build - watch this space.
This strikes me as odd, considering that ACEScg was designed specifically for computer rendered images, whereas all of the other specs were intended as a translation for live action footage. What drove that decision?
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
