In short, a lot of 3DSMax die hards explain in the following thread why they have abandoned updates after this the 2009 release:
http://www.polycount.com/forum/showthread.php?t=104082
Also, it is great to read that there are so many other Max users that are equally frustrated about the version cycle Autodesk has chosen.
So this is a +1 for Octane for 3DSMax 2009
Why 3DStudio Max 2009 support is still desirable
The problem is to develop and project all versions.
2009, 2010, 2011, 2012 and current 2013 are 5 versions. In the worst case, each version uses an other api.
Use this with 32/64bit, you will have 10 different versions. If you must debug something, you will have 20 versions.
All in all, you have 5 projects with 4 versions each.
face
face
http://vimeo.com/user2509578
- temp-64GTX
Win7 x64, [email protected], 32Gb DDR3 1600, 2xGTX580 3Gb, Corsair 64Gb SSD, ViewSonic 2560x1440
