PC chrashes when activate both "Use for tonemap"
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
moebius
A. win10
B. 2x GTX 1080 Ti
C. 27 GB (?) not sure
D. 26.21.14.3186
E. -
F. 2019.1.4
G. -
H. PC chrashes when activate on both Graphics Cards "Use for tonemap"
I. where do I find that?
D. What's your driver version? Numbers are not known by me
Also post bugreport.zip, it's required.
moebius
Driver is that what it says, and Windows says I have the best drivers it can find
maxon folder "_bugreports" is empty. I'dont get bug report, when C4D starts new.
the Nvidia driver should be good, Studio 431.86, please post a screenshot of c4doctane Settings/Devices panel, and another one similar to this:
ciao Beppe
moebius
oh, i fount the driver: it's 431.86. I see, there is a new one 441.28, shoult I install it?
Please, download and run GPU-Z:
https://www.techpowerup.com/gpuz/
And share a screenshot from the Graphics Card tabs from both GPUs, thanks.
If it crashes with Tonemapping active, probably the PCI bus of the second GPU is too slow.
Please also post a screenshot from c4doctane settings/Devices panel, thanks.
ciao Beppe
moebius
Hi Beppe
here some screenshots, thanks a lot!
Please, try theses steps.
  • Go to Nvidia Control panel, menu Help, and enable the Debug Mode, to work with GPUs at default clock.
  • Connect one monitor per GPU, to reduce the available VRAM more uniformly .
  • In Devices panel, enable the Priority for both GPUs, and set the Priority popup to LOW
ciao Beppe
moebius
nop. :-(
But actually, I don't need "Use for tonemap" for both GPU, so I break up to test stuff...
Return to “Bug Reports”
