CUDA error 2: out of memory
Chillkroete
I have two 1080ti and I´m using Version 4.05-R6.
Since my last big project (full usage of vram) I get the message even in small scenes.
What does it mean exactly?
Kind regards.
Vram usage
Vram usage
failure message
failure message
Please, run OctaneBench 4.00c:
https://render.otoy.com/downloads/a/787 ... 0c_win.zip
If you are having the same error, the issue is in the Nvidia driver.
Please, share os exact version, GPU model, and Nvidia driver version, thanks.
ciao Beppe
Chillkroete
Hi beppe, thanks for you answer.
Running the octane bench is no problem.
I have two ZOTAC 1080 Ti (ZT-P10810B-10P) and installed the nvidia driver 26.21.14.4128 (Nvidia 441.28).
My OS System is Windows 10 Home.
Octanebench result
Octanebench result
Chillkroete wrote:Hi beppe, thanks for you answer.
try with standalone 4.05, as said that you need older stable drivers. Also running the renderer from host(C4D) that can give different issues which you can't see in standalone.
affixxius
I just had a similar issue, the company that deals with our network updated my windows 10, this updated the drivers too.
I rolled back to 431.86_Studio and it solved the stability issue.
// Windows 11 // 2 x RTX3080 // 4x GTX1080Ti // Octane Latest // Cinema 4D Latest //
