Cinema 4D version 2019.1.4-R2(Obsolete stable) 07.12.2019
Forums: Cinema 4D version 2019.1.4-R2(Obsolete stable) 07.12.2019
Moderator: aoktar
Re: Cinema 4D version 2019.1.4 (Stable) 12.11.2019
Postby aoktar » Mon Dec 02, 2019 9:27 pm
aoktar Mon Dec 02, 2019 9:27 pm
lukas8410 wrote:I may have experienced a bug.
So I am trying to use "Layered material" and when I am trying a "metallic layer" with RGB IOR, and try to enter some numbers C4d doesn't allow me to enter any numbers below 1.0. I was able to do that, and in fact still am in other material types (haven't tested them all) but not here. I've been trying to enter and even copy the number in various ways with no success. I am sorry if this bug was described earlier, but I do not have time right now to venture trough the forum.
Cheers,
Luke
There's some overlook on gui parameters
Postby aoktar » Mon Dec 02, 2019 9:29 pm
aoktar Mon Dec 02, 2019 9:29 pm
jessestormer wrote:I believe that currently -- while the 'enable network rendering' checkmark is ticked off in render settings, daemons are being picked up anyway during a render. As if 'network render' is constantly switched on and possibly with 'use steal' and 'bind all' as well. -- I currently need to keep computers' daemons closed during renders or else they all try to pick one-another up as slaves and crash.
Check your network parameters in Live Viewer. It can be active from there
Postby SSmolak » Tue Dec 03, 2019 10:29 pm
SSmolak Tue Dec 03, 2019 10:29 pm
Little bug : when cloner instances are set to render instances Octane render them fine, but when they are set to multi-instances Octane always render one instance less than cloner. Please fix this. Multi-instances are way faster in viewport. Thanks.
SSmolak
Postby aoktar » Tue Dec 03, 2019 10:34 pm
aoktar Tue Dec 03, 2019 10:34 pm
SSmolak wrote:Little bug : when cloner instances are set to render instances Octane render them fine, but when they are set to multi-instances Octane always render one instance less than cloner. Please fix this. Multi-instances are way faster in viewport. Thanks.
Fixed it for next build
Postby divasoft » Wed Dec 04, 2019 10:22 pm
divasoft Wed Dec 04, 2019 10:22 pm
Hi Ahmet, Image sequence not updated on render (animation on screen display).
I sent you a scene file in messages.
https://yadi.sk/i/-wfu4ml5NgxZVw
divasoft
Postby aoktar » Wed Dec 04, 2019 11:41 pm
aoktar Wed Dec 04, 2019 11:41 pm
divasoft wrote:Hi Ahmet, Image sequence not updated on render (animation on screen display).
It started to update after connecting/disconnecting the image to albedo pin
Postby divasoft » Thu Dec 05, 2019 12:53 am
divasoft Thu Dec 05, 2019 12:53 am
But i don't need albedo at all. I use texture emission node for sequence.
divasoft
Postby divasoft » Thu Dec 05, 2019 9:39 am
divasoft Thu Dec 05, 2019 9:39 am
I created a connection for Albedo, but the animation still doesn't work. Is there any solution? Ahmet?
divasoft
Postby aoktar » Thu Dec 05, 2019 9:43 am
aoktar Thu Dec 05, 2019 9:43 am
divasoft wrote:I created a connection for Albedo, but the animation still doesn't work. Is there any solution? Ahmet?
Don't know, create a new material. There should be a glitch in material
Postby divasoft » Thu Dec 05, 2019 9:51 am
divasoft Thu Dec 05, 2019 9:51 am
I already did this, it still doesn't work.
divasoft
PreviousNext
Return to Releases
Sun Jun 16, 2024 12:21 am [ UTC ]
