i second the sentiment of thankfulness for Otoy's team.
Everyone has been so helpful, no matter the frustration i encountered so many times using Octane.
Best customer support among a lot of vfx tools i personally use, hands down.
Beside this, i would love to see the Lights ID passes denoised as well,
that could be very helpful,
thanks guys
marco
marcoiozzi.com
AI Denoiser is awesome - thank you, OTOY
Good morning (o;
Has someone a trick how to improve denoising in a scene with a carpet on the floor?
Looks just washed out and smeared...
thanks in advance
richard
thanks in advance
richard
Debian 10.2 on AMD 1950X, 64GB RAM, 2 * RTX2080Ti
Octane Blender Studio 2020.1-XB3-21.3
Blender 2.83 E_Cycles
- richardwright
I get zero denoising
Octane Camera Imager is on for both Render and Preview.
Spectral AI Denoiser is activated in both the above.
I think Render Passes is turned on - there isn't a tick box like in the 2.79 but I've ticked a few passes and can see them in the F12 image.
Preview pass is set to Denoiser Beauty.
Beauty pass is ticked.
Denoiser Beauty pass is ticked.
And finally in Compositing - Use nodes is ticked and OctDenoiseBeauty is hooked up.
Max Samples are set 10 & 10 in Path Tracing Kernal.
Running latest version of OctaneRender 2019 for Blender 2.8 free tier
You need to increase render samples.davorin wrote:Good morning (o;
thanks in advance
richard
System – Windows 11
System – Windows 11
This should work with settings you described. Can you share the Blend file?richardwright wrote:I get zero denoising
System – Windows 11
System – Windows 11
- richardwright
I had to recreate the scene. Think this is set how I had it. Might have missed something.
- Denoiser.blend
- (1.05 MiB) Downloaded 247 times
Change "Preview pass type" to composite and it will work in final render.
For most cases preview pass should be set to Composite when doing final render (F12).
System – Windows 11
System – Windows 11
- richardwright
After the render have you switched to denoised view layer in picture viewer?richardwright wrote:Not working for me.
Please check this file out. It's a simple scene with denoiser:
System – Windows 11
System – Windows 11
