Hi All,
I'm rendering a fairly simple scene, but for some reason my gpu won't acelrate above 5% and rendering a full hd image cost about 6 minutes on average to render.
I've set my priority to high and attached the project file to this as well..
Not sure what I am doing wrong.
I have a fairly low-end set up, but even with that these times are very very low.
ON average the cpu also doens't go over 5% and the ram up to 50% when i look at the read of my task manager.
I have :
an i7 4790K cpu @4ghz
32 gb ram
Gigabyte Geforce 1070Windforce OC 8gb
os: windows X Pro
Any insight as to why this is so incredibly slow and doesn't seem to make full use of what I have is welcome!
Octane sees my GFX card, but somehow hardly uses it...
I'll check your scene if you put here
make a RAR or ZIP and upload
thanks! Is there any specific reason to use specular material on floor and having caustic_blur?
I was modelling a sign of an actual sign, which normally hangs on a wall in a club,
which hangs on perspex.
I wanted also to have some nice moody reflections to basically give it a bit more depth.
Caustic_blur, is that on the material or on in the render?
If I have it turned on in the render, then perhaps I did that by mistake.
I cannot find any effective optimisation for this scene. It's rendering at 1:24 on my two 2080s, your 1070 is slow enough for this..
