Cinema 4D version 2019.1.3 (Stable) 03.11.2019
EINBLICKE
Is there already the right enterprise slave version?
Shordy
EINBLICKE wrote:Is there already the right enterprise slave version?
Enterprise Slaves has now a separate installer. You will find this in the download section. 2019.1.2 & 2019.1.3
Ive tested it and it works.
EINBLICKE
Perfect - thank you!
tomsvfx
Cinema 4D hangs forever and needs to be force shutdown when:
While LiveViewer is open and rendering, we do some edits and change viewports with middle mouse button (it crashes when we switch from quad view to single view) , a lot of times it crashes when we do this.
Edit: Seems like it also crashes when moving around in viewportt with ALT+Middle Click
tomsvfx wrote:Cinema 4D hangs forever and needs to be force shutdown when:
Please give some usefull data. Not possible to know what happen with this information. And I work like that every minutes without problems.
Give a full information about your system and software setup. Also record c4doctanelog.txt with all log parameters. And define is it scene specific or common issue.
tomsvfx
PC specs:
Window 10 (1903 build 18362.418)
Nvidia Studio Drivers 441.12
C4D R21.026
It has happened for 3 people at work with different scenes, same exact problem/scenario.
For some reason I cant replicate it while log checkboxes are turned on :D
But prevously crash happened like this:
I open LiveViewer and press render and start doing changes to lights while its rendering.
After some while, I switch to quad view and move some lights in other view.
When I switch back to single view, C4D crashes or freezes and doesnt unfreeze.
Witch switching from quad view to single views and back and forth I mean this:
https://www.youtube.com/watch?v=3TQSPjW ... tu.be&t=47
^ for some reason this also triggers LV refresh
divasoft
Aoktar, please, any advice to fix universal camera pixel aspect?
viewtopic.php?f=85&t=73081&start=20#p371988
FullHPetroL
Does displacement mixer work?
As for me, it either doesn't work, or crashes the moment I use it.
Displacement Mixer Issue.rar
(5.81 MiB) Downloaded 353 times
displacement Mixer is rock solid here with 2019.1.3, maybe you have an issue with Nvidia driver.
To make it works in your scene you need to change the Displacement type to Vector Displacement, and change the Map type to Height.
ciao Beppe
Bulwerk
I'm not having success using a fields driven vertex map as an input for the "Blend weight" of Displacement mixer.
Auto bump works with the mask giving the illusion that the surface is deformed but the actual vertex have not moved.
Seems like all other shader inputs work just fine. Is this a core issue or am I doing something wrong? Scene file attached.
Vertex Map Displacement Mixer problem.zip
(168.51 KiB) Downloaded 302 times
Return to “Releases”
