v4 Vertex Map Crashing
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Affari
A. Win 10
B. 2x GTX Titan Pascal
C.32gb
D. Nvidia driver version 431.86
E. OctaneRender Standalone 4.05
F. OctaneRender plugin 4.05
G. C4D R21.023
H. Drag Vertex Map node in node editor and then drag the Vertex Map tag into slot via node editor, causes instant crash.
I. Please see files below
I've tried installing new nvidia driver and still crashes on vertex map insert.
I need vertex maps for a project I'm currently working on for use with fields, I wouldn't mind if it crashed occasional but this seems to be a recurring crash when used in the node editor.
I've added bug reports folder for you:
_BugReport_01.zip
(100.73 KiB) Downloaded 281 times
And also the C4D file where you can try the steps yourself? Just drag vertex map into vertex map slot in the mix texture within the node editor.
C4D.zip
(359.84 KiB) Downloaded 315 times
Please help :/
Windows 10 Home // Octane Version 3.05.3 // Nvidia Driver 378.66 // Cinema 4D R18 Plugin 3.05.3
Asus X99-E WS // Intel Core i7-6800k // 2x 12GB NVIDIA TITAN X (PASCAL) // Corsair Vengeance LPX DDR4 3000 32GB
everything is working as expected here with your scene:
Since you have a Titan X Pascal under Win 10, please, perform a clean installation of 431.86 Nvidia Studio driver:
https://www.nvidia.com/download/driverR ... 1050/en-us
To perform a clean installation, please follow these steps:
ciao Beppe
AlejandroDL46
A. Win 10
B. 1 RTX 2080 & 1 GTX 970
C.32gb
D. Nvidia Studio Driver version 431.86
F. OctaneRender plugin 4.05 V6
G. C4D R21.026
Hello. I'm having the same issue with octane 4.05 V6 using a RTX2080
I've installed the latest Studio Drivers using clean installation option but the problem persists. I'm not able to use any vertex map even on a simple scene.
Is this a common issue?
I'm not able to reproduce it. But you can use 2018 because it's using native support for vertex colors. It works much faster and better.
AlejandroDL46 wrote:A. Win 10
C.32gb
G. C4D R21.026
Please, double check, because you cannot install Studio driver with 970, you need Pascal, Volta, or Turing GPU to be able to use Nvidia Studio driver.
Is it possible for you to temporarily remove GTX 970?
Alternatively, try to go back to 419.67 Game Ready driver with a clean installation:
https://www.nvidia.com/download/driverR ... 5534/en-us
ciao Beppe
Affari
Sorry for late reply was busy with another project...
This is still happening, I've tried on 2 machines now this one being the OP machine that has 2xTitan X Pascal and then my home machine which has 3x1080ti's and the same version of Octane 4...Exact same error.
Me showing steps of consistent crash.
I've tried reinstalling Nvidia drivers too, clean install...However, there are literally no other issues with Octane so how can this be a driver issue? I can work hours with Octane no problem, just when using the vertex map I get this issue literally every time no fail on 2 completely different machines...
Octane 4 has kinda been left and 2018/19 being worked on so do you think this could be a bug in the Octane 4?
Edit including log:
_BugReport.zip
(103.82 KiB) Downloaded 282 times
Affari
2019 Demo....Works without ANY issue everytime..
Click to view gif
Click to view gif
Maybe I'm being forced to upgrade?
kaisdaddy
Same issue here on a Mac M1 Ultra with 128GB of ram and 64 GPU cores. Any time I assign a vertex tag to a vertex map node it causes C4d to freeze. This is true both with C4d R25 and R26/2023. On R25 I'm using the latest stable release PR14 and on R26 I'm using the 2022.1 XB 3 experimental release. I can repeatedly get the same bug with both versions.
This is seriously affecting my ability to get work for paying clients out the door. PLEASE fix this and get the 2022 version stable. I love new features but I just need existing ones to work and not crash the host application. Thanks!
- H
Return to “Bug Reports”
