Uv map break in octane material
baghbanikm
why in my render
uv map deform in far segment ?
Sorry but did you check the uvw in viewport/renderer with a standard material?
omardex
Hi, If you are using Sds to smooth your geometry make sure that the subdivide Uv is set to edge, if not stretch like that happen.
Annotation 2019-10-08 120152.jpg (10.44 KiB) Viewed 3874 times
if is not that, check the projections in the object manager for your material, or the projection node in your octane material textures if it exist. and make sure that are set to mesh uv and/or uvw mapping projection
Omar Tavera
Awesome Generalist
omardex.artstation.com
Octane render for c4d but moving more toward standalone with one 980ti
baghbanikm
aoktar wrote:Sorry but did you check the uvw in viewport/renderer with a standard material?
i cant believe, also in c4d render is not ok
baghbanikm
omardex wrote:Hi, If you are using Sds to smooth your geometry make sure that the subdivide Uv is set to edge, if not stretch like that happen.
thank you .
but i didnt use ss in this object
frankmci
Compare your actual geometry to your UV space. Notice how your poly rings are evenly spaced, yet in your UVs, they are clustered closer to the rim. You need to adjust, or probably more simply, re-project your UV mapping so that you are not introducing distortion.
The distortion you are seeing.
Your current Polys on Left, UVs on Right. (No texture for the sake of clarity.)
1:1 Polys to UVs, no distortion
baghbanikm
frankmci wrote:Compare your actual geometry to your UV space. Notice how your poly rings are evenly spaced, yet in your UVs, they are clustered closer to the rim. You need to adjust, or probably more simply, re-project your UV mapping so that you are not introducing distortion.
Thanks a lot
