Hi Paride,
I am attaching 4 different scenes each one has its own problems with motion blur and particles. Plus 3 visual images and one short video. Please look at them. I am not sure what to think.
A. Scene01 - Pflow motion blur has wrong directions. Super spray works fine. If you go to Pflow events, then choose octane properties and turn off movable proxies and MB - particles will disappear. If you check the boxes back Max can just crash.
B. Scene02 it just crashes max when octane viewport is opened. Something to do with pflow and octane motion blur
C. Scene 03 motion blur just does not work at all even though it is enabled. BUT if you merge an object as xref objects motion blur can start working again. (similar problem with the scene i sent to you with bricks not having mb)
D. Scene 4 Super spray has no motion blur enabled but octane is not rendering lines the same way what viewport shows. In octane viewport sparks dont fly the same direction. Adding octane modifier can fix the problem but sometimes it just doesn't work during normal rendering. It seems that octane modifier only works when rendering starts during particle emission not before. Something is not getting updated or octane doesn't find out about the modifier during rendering.
Plus in octane mod special type must be set to NONE for proper particle travel instead of 'Extended geometry' (but developers said Extended geometry posting.php?mode=quote&f=80&p=359157)
I never had these problems in octane 4. These are normal scenes.
Could you let me know what I am doing wrong and send them to developers?
I am hoping they can fix all these in the next release: this bug, mb does not work at all with bricks, mb for phoenix liquids, crash/no update with ramp emission textures and phoenix fire, crash when adding octane particles modifier, foam and splashes are treated as static geometry, glass is not clear in AO, bug with moving instanced objects. That's a lot of bugs and we cannot continue work at all.
Thank you
Pflow incorrect MB and 3ds max crashes
C. RAM Capacity (i.e. 6 GB)
- Scene04 superspray wrong direction.zip
- (135.13 KiB) Downloaded 276 times
- Scene02 CRASH.MOV
- (663.27 KiB) Downloaded 1761 times
- Scene 03 no stop motion at all.zip
- (1.55 MiB) Downloaded 291 times
- Scene 02 Crash.zip
- (661.71 KiB) Downloaded 270 times
- Scene01.zip
- (1.55 MiB) Downloaded 275 times
- neonZorglub
Hi coilbook,
Thank you for your scenes and video !
I could reproduce the crash in Scene02; it comes from the SuperSpray, the 'Special type' setting 'Extended geometry support' in the modifier is incompletely restored when loading the scene.
The crash do not happen when setting it to None before opening the viewport, and then set it again to extended geometry ..
For Scene 01, the incorrect direction comes from not having or not using velocity..
I'll go throw the other issues, and release a fixed version asap.
Hi neonZorglub,neonZorglub wrote:Hi coilbook,
Than you for your help. Could you also look at this bug viewtopic.php?f=81&t=72795. We cannot adjust ramp emission in real time and get crashes Octane 4 worked fine
Thank you
