Cinema 4D version 2019.1.1-R3 (Stable) 09.10.2019
vfxfreek
Does this version support RTX ON ?
gohmn
Motion blur on splines does not seem to be working for me. Octane object tag is applied, render as hair is on, and transform/vertex is on. Here's a small test scene. - https://www.dropbox.com/s/ztuveod0bvc9z ... t.c4d?dl=0
divasoft
Vertex Map inversion attribute is broken
https://drive.google.com/open?id=1_vNA0 ... 6LneCPfR6n
divasoft
Octane scatter still not stable sometimes. Grids and patterns instead random distribution.
divasoft wrote:Vertex Map inversion attribute is broken
It's not an implemented parameter.
divasoft wrote:Octane scatter still not stable sometimes. Grids and patterns instead random distribution.
Scatter object is a free bonus and it will not get updates. Tweak your distribution surface to fix that pls
FelipeCortes
in new Composite material, dirt node dont show in difuse channels, only in masks
divasoft
Hi Aoktar. I am exploring various instance creation plugs, but they all work quite slowly and not efficient. In usual case, 2 000 000 render instances will be parsed for rendering for about 2 minutes on my computer (if i scatter simple sphere), while your octane scatter does this almost on the fly. Tell me, is it possible for a third-party plug to achieve octane scatter speed, or should I not hope to find such a plug-in?
divasoft
Another bug in node editor. I can not move node and octane shows strange ui element.
https://drive.google.com/open?id=1VPqh2 ... D4A2GqNMki
divasoft wrote:Another bug in node editor. I can not move node and octane shows strange ui element.
Thanks! I know it, it's not a bug. Just didn't disable a non-complete color gui.
Return to “Releases”
