Phoenix FD Foam & Splashes problem
remKa
Hello Paride,
I'm working on a boat simulation and I have an issue with foam and splashes particles animation : they stay still while the liquid is updating nicely..
Is this a known issue ?
Thank you in advance
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
paride4331
Hi remka,
After some test, I think I've found an issue and sent to developers.
A workaround is using Octane for 3dSMax 2018 - 7.09, put foam in Target node name, then open your file in 7.11
remKa
Thanks !
Did you ask developpers how to make the Ocean mesh working with the phoenix ocean displacement texture ? I'm still having an issue there
paride4331
Hi remka,
it is in developers to-do fix list.
remKa
Hell Paride,
I've put "foam" in target node name" in 7.09 and I've rendered it on 7.11 but particles are still not updating in the animation (with SHIF+Q).
What's weird is that when I'm scrolling the timeline manualy with the Octane Viewport active, the particles are updating well
paride4331
Hi remKa,
you would set your scene to movable proxy.
01.mp4
(488.32 KiB) Downloaded 3475 times
coilbook
remKa wrote:Thanks !
did you try to enable in octane support phoenix dialog?
remKa
Yes, it was ON everytime I tried !
Did you manage to make it work ?
coilbook
remKa wrote:Yes, it was ON everytime I tried !
No. We had this bug many years ago and that's why they added this checkbox. I didn't know it is not even working.
coilbook
did you try to set Notify objects on render to ALL objects in render settings ?
Return to “Autodesk 3Ds Max”
