Cinema 4D version 2019.1.1-R3 (Stable) 09.10.2019
pxlntwrk
aoktar wrote:Ok, It's not a plugin issue. I've reported to Octane devs. Btw It doesn't happen one me, maybe you do something different. Or it's related with your hardware.
ok nice,
on the other hand I rematched that I have no error with the shadow catcher feature, when I use only the 2080ti by unchecking the 3 1080ti.
Maybe this is due to the mix of different hardwares?
What is curious is that this does not happen in the standalone or in the previous version 2019.1 of the c4d plugin?
pxlntwrk.net
ok nice,
I cannot know, it's renderer related under hood. We only do connection between host and core. Rest is up to renderer.
adamwhatelse
aoktar wrote:
pxlntwrk wrote:
roinigo wrote:Hi! You should try with newer Nvidia drivers. I upgraded to 436.30 and it solved the issue for me.
thanks for answer, but same result with 431.86 and 436.30 drivers.
Thx for reporting it aoktar!
I have the same issue. With one or both gpus active, and also not depending on which driver I use (the last try was with 431.86) , with R20. Hope they fix it soon.
octane 2019.1 190923 230245.log
(3.25 KiB) Downloaded 281 times
roinigo
Works for me with both RTX2080Ti + GTX980 checked...
ASUS PRIME X470-PRO
AMD Ryzen 7 2700X 8 cores
Noctua NH-U12S SE-AM4
G.SKILL FLARE X SERIES 64 GO (4X 16 GO) DDR4 2933 MHZ CL16
RTX 2080 Ti + GTX 980
Seasonic PRIME 1000 W Gold
Fractal Design Define R6
adamwhatelse
Is there a way to roll back to 2019.1 RC3 r2 ? When I try, I get the message that that build isn't supported anymore, although I just used it today, before installing the 2019.1(stable).
It would be really neat to be able to use RC3, until the shadow catcher issue is fixed...
Kalua
aoktar wrote:
ok nice,
I got the very same issue. Windows 10, 64, Driver 431.86, 3xGTX 1080, R20. Shadow catcher crashes Octnae in C4D.
Standalone works flawlessly.
Octane User since V1 Beta
Kalua wrote: I got the very same issue. Windows 10, 64, Driver 431.86, 3xGTX 1080, R20. Shadow catcher crashes Octnae in C4D.
Standalone may work flawlessly that doesn't mean SDK doesn't have problems. When we use the Renderer in a host there's extra factors to cause problems. For example; material previews or Host software's Opengl/Gpu usages.
Make a test without octane previews are enabled or with software opengl.
pxlntwrk
Hi and thanks,
it works by disabling the materials preview. :D
Overview in the material manager remains grayed.
on the other hand when I test only with the 2080ti, everything works even with the feature "material preview" enabled,
but the preview becomes black, which is not a normal behavior compared to the old version where the preview remained white?
pxlntwrk.net
BCres
Thank you for the quick fix on the LiveDB. I appreciate all the work you do on this plugin, aoktar.
VVG
roinigo wrote:
Indeed... Does the Studio DRIVERs are preferable for Octane Render ?
yep, Studio more stable.
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
Return to “Releases”
