Render failure
It's not correct driver I pointed.
If it's not a driver issue, that's a hardware problem on your side.
Alexisbaydoun
Is this a common problem? Would it normally crash if i download another version?
And in case i install the driver and its a hardware problem does this mean i need a new Graphics Card or it could be something simple?
Alexisbaydoun wrote:Is this a common problem? Would it normally crash if i download another version?
Advice this driver because I had problems with latest drivers. Select clean install option while installing it. It should be a HW problem if still happen after that.
Alexisbaydoun
if i select clean install it will automatically delete the 436.30 version i already saved and save 431.70 over it?
if its a HW problem does this mean Graphics Card need to be changed or it could be something more simple?
Yes for first question,
I'm not sure for the second. But the reason for these errors most likely is HW problems. That's what I have seen from user reports until now.
Alexisbaydoun
I was capable of rendering this scene using Physical in just less than 10 minutes, 3000 pixels wide. The Physical renderer seems to be working just fine.
This is the temperature while it was rendering: 33 degrees, Memory used 800 MB, GPU load 3%, CPU Temp: 75 degrees, System Memory used 9 GB.
Does this mean that indeed the GPU is not working? or that it's just NOT connecting to the GPU hence why Octane is failing? Maybe i need to link the GPU to Octane so that Octane starts using it? cause clearly its not using the GPU..
This is how its looking before its crashing
This very simple scene opened up on Octane then stopped rendering 20 seconds after it started
I really need a professional confirmation from you guys before i go ahead and buy a new $600 graphics card, mine isnt even 2 months old. Appreciate the help.
Alexisbaydoun
Hello,
Any feedback?
please, open the scene, then go to c4doctane Settings/Others tab, and, at the bottom of the panel, enable all the Log option checkboxes:
Then, load the scene in Live View, then in Picture Viewer until crash, and share the c4doctanelog.txt file that you find in c4doctane directory, or in the path specified in Settings/Others panel, thanks.
ciao Beppe
Alexisbaydoun
c4doctanelog.txt
(72.59 KiB) Downloaded 939 times
there you go. this scene reached 360/16000 samples then stopped rendering
My last reply on this topic,
Use latest studio driver not game ready. And check gpu temperatures on rendering..
Return to “OctaneVR Questions & Discussion”
