Cinema 4D version 2019.1.1-R3 (Stable) 09.10.2019
Silverwing
aoktar wrote:
Silverwing wrote:Network rendering in fundamentally flawed in this release.
Just open a new scene and render a cube with network rendering enabled. The slaves contributions will show up tinted in all sorts of colors.
It also behaves this way if I export the cube in Standalone.
Network or similar core functionalities not related to plugins. Better to move your post to standalone topic.
Hi Ahmet. Thank you for your answer!
Yes Its definitely a core thing. I will post it in the standalone forum.
WIN 10 PRO 64 | ASUS X99-E WS | 3 X GTX 1080Ti | i7 5960X 8X 3,33GHz | 64GB RAM
roinigo
Hi aoktar,
Thank's for this release !
I still get "V4.5-R2" number in the live viewer. Is it normal ?
ASUS PRIME X470-PRO
AMD Ryzen 7 2700X 8 cores
Noctua NH-U12S SE-AM4
G.SKILL FLARE X SERIES 64 GO (4X 16 GO) DDR4 2933 MHZ CL16
RTX 2080 Ti + GTX 980
Seasonic PRIME 1000 W Gold
Fractal Design Define R6
roinigo wrote:Hi aoktar,
Saved layout, fixing the closing and open it again?
pxlntwrk
aoktar wrote:
pxlntwrk wrote:Hi,
shadow catcher seem Broken.
Create Material, unable shadow catcher > render failure
How could you decide that's broken? It's working on my trys. What's your driver version? It may be a problem with your setups.
it's the same on my R19 and R20 OctaneRender-for-C4D-2019_1_win,
but against the feature works properly with the Stadalone OctaneRender_Enterprise_2019_1_win
what changes to setup settings would you recommend to test?
ps/ C4d r19.068 & r20.059 , Win 10.1903, rtx2080ti + 3x gtx1080ti , nvidia 431.86
c4doctanelog.txt
(174.45 KiB) Downloaded 241 times
pxlntwrk.net
roinigo
Of course! ;) Thank you!
ASUS PRIME X470-PRO
roinigo
pxlntwrk wrote:
aoktar wrote:
pxlntwrk wrote:Hi,
Hi! You should try with newer Nvidia drivers. I upgraded to 436.30 and it solved the issue for me.
ASUS PRIME X470-PRO
VVG
436.30 it`s GEFORCE GAME READY DRIVER
431.86 NVIDIA STUDIO DRIVER
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
roinigo
Indeed... Does the Studio DRIVERs are preferable for Octane Render ?
Studio Drivers seem to work only with recent GPU. I need GTX980 to plug one of my monitor... :(
ASUS PRIME X470-PRO
pxlntwrk
roinigo wrote:Hi! You should try with newer Nvidia drivers. I upgraded to 436.30 and it solved the issue for me.
thanks for answer, but same result with 431.86 and 436.30 drivers.
pxlntwrk.net
Ok, It's not a plugin issue. I've reported to Octane devs. Btw It doesn't happen one me, maybe you do something different. Or it's related with your hardware.
Return to “Releases”
