OctaneRender® for 3ds max® v2019.2-XB3 - 9.01 TEST
coilbook
paride4331 wrote:Hi coilbook,
here for you.
Thank you!
HHbomb
octane 2018 : 2x2080 ti + 4xtitanX ---> 3mn30
octane 2019.2xb3 : 2x2080ti ---> 8mn
octane 2019.2xb3 RTX on: 2x2080ti ----> 2mn15.... Impressive.
But renders are different 2018 vs 2019, less details in dark in 2019.
coilbook
3 problems
1. With rtx support on octane crashes with gpu failure message for some reason not using ram
CUDA error 2 on device 0: out of memory
-> failed to allocate device memory
device 0: failed to upload data texture 34 '0:__data31__'
2. There is no sun not sure why. 2019.1 works fine
3. Samples jump from 1400 to 0 video is attached
xb3 strange sampels.MOV
(849.22 KiB) Downloaded 2466 times
HHbomb
1500 Sampl/s ….
edit : I have Gpu failure too, but I don't know why ? I suspect octane lights with new Vectron option...
ramone163
2x2 upsampling seems don't work
rendert time:
without upsampling - 1:49
2x2 - 1:49
4x4 - 00:30
Again and again. How do you test new builds?
GPU: 2x4090; 3ds max;
Behance portfolio; Handmadefont.com;
ramone163
paride4331
Hi ramone163,
this is a test version, XB3 is not even available in Standalone, new features will be added gradually and some issue depends on SDK.
Return to “Releases”
