Cinema 4D version 4.05-R7 (V4 stable) 25.10.2019
CTAKAHCEMOK
Material preview do not work
r21, 4.05-R5
CTAKAHCEMOK wrote:Material preview do not work
r21, 4.05-R5
We talked about it before. It's a problem of R21 C4D sdk. Reported to Maxon
kaisdaddy
Any update on the shadow catcher issue? If there's a work around to get it working, please advise. Thanks!
kaisdaddy wrote:Any update on the shadow catcher issue? If there's a work around to get it working, please advise. Thanks!
Asking for a core issue, cannot know the answer.
stuz0r
r21, 4.05-R5
If you copy and paste the material it shows up as a preview. I accidentally figured this out. haha
desire
Sorry, but again noisy Shadow Pass while using Render Layer feature. And with fireflies.
Win 7 64bit Cinema 4D R20.059
GTX780 + GTX1080 + GTX1080ti + GTX1080ti
100% view
100% view
Hi desire,
if you have the Adaptive Sampling option active in the Kernel panel, try to disable it, and report back, thanks.
ciao Beppe
desire
bepeg4d wrote:Hi desire,
ciao Beppe
Ok, will write the result soon. Thank you for reply.
3dworks
i didn't get any reply for my previous post here and hereviewtopic.php?f=30&t=70339#p368842 about OSL node crashing cinema. for the crash scene, see attachment. it's a windowbox OSL scene which was posted on this forum a while ago and which is crashing C4D as soon as you try to open the OSL node in node editor.the OSL shader renders fine, but it is useless if you cannot edit it.
WindowBox_C4D.zip
(7.94 MiB) Downloaded 278 times
Specs: Apple MacBook Pro M1 max 64GB 2TB, MacOS 12.5 / MacPro 5,1 with NVIDIA GeForce GTX 1080 8G, MacOS 10.13.6 / Mac Pro 5,1 with AMD RX5700 8G, MacOS 12.3.1 / HP Z600 with NVIDIA 3060 RTX 12G, Windows 10 pro + Netstor GPU box, 4 x NVIDIA GTX 980ti 6G.
3dworks wrote:i didn't get any reply for my previous post here and hereviewtopic.php?f=30&t=70339#p368842 about OSL node crashing cinema. for the crash scene, see attachment. it's a windowbox OSL scene which was posted on this forum a while ago and which is crashing C4D as soon as you try to open the OSL node in node editor.the OSL shader renders fine, but it is useless if you cannot edit it.
Answered it somewhere! It doesn't crash on my trys. Please capture a video and c4doctanelog.txt with all log options and send me.
Return to “Releases”
