Can't get LUTs to work
Sub forum for bug reports
Moderator: ChrisHekman
EvolverInteractive
That's just it. I can't seem to get LUTs to work. I thought it was Unreal and they use a texture LUT. Then I was like okay, I'll just use a .cube LUT instead like normal. hmmm no change.
ChrisHekman
This has been fixed. Will be part of the next build.
ChrisHekman
This is now fixed in the latest release.
EvolverInteractive
Working great,
If it is pre-loaded in a scene it, needs to be unloaded and loaded again. But hey it works.
ChrisHekman
EvolverInteractive wrote:Working great,
Great :)
What do you mean with pre-loaded?
EvolverInteractive
What I mean by pre-loaded is when I jump back into a scene or project the the LUT has already been applied. It's in the slot as selected but for some reason not work. So I have to select another LUT and then go back to the one I had already used. Then it works. So in short. If you save the scene with a LUT you have reload the same LUT for it to work again.
ChrisHekman
This issue has been fixed in the latest build.
Return to “Bug Reports”
