Cinema 4D version 4.05-R7 (V4 stable) 25.10.2019
carterner
bepeg4d wrote:Ok, please remove the manual folder, and move the help folder directly into the c4doctane folder.
ciao Beppe
Unfortunately, I am still here to go online, I have tested this before. I want to cry~
carterner
help me~
Hi carterner,
sorry, I have no more ideas, here it is working as expected, and now your path seems correct :roll:
ciao Beppe
divasoft
I found another bug. Please fix it.
https://drive.google.com/open?id=1K2JKz ... H7HIFADn9a
divasoft
thin wall in 4.05 release sub material? And Thin wall option has no effect on result in 2019.1 r2 release.
divasoft wrote:thin wall in 4.05 release sub material? And Thin wall option has no effect on result in 2019.1 r2 release.
It's not a part of V4. I forgot it to remove.
divasoft
Can you add short menu to light and mediums UI instead of "..." btn? (float, rgb spectrum, img texture) This small addition will makes our pipeline much more faster and handy.
Thanks.
divasoft wrote:Can you add short menu to light and mediums UI instead of "..." btn? (float, rgb spectrum, img texture) This small addition will makes our pipeline much more faster and handy.
Thanks.
It's possible I think by some changes.
84rt-design
hi ,
my render sequence is crashing with "bugreport" after couple of picture rendered well , here is my spec threadripper 2990wx 2 rtx 2080ti with nvlink (sli deactivated) 64 gb ram , here is my file bugreport https://drive.google.com/file/d/1s9mTk0 ... sp=sharing
can you help me ? thanks
84rt-design wrote:hi ,
I cannot know what happen with this file. Just seeing a crash at renderer core. Check you're in out-of-vram or not.
Return to “Releases”
