OctaneRender for Maya 2019.1rc3-15.5 [OBSOLETE]
Moderator: JimStar
BK
- Thank you Braca, for your help.
BK, funny part is now I cannot make it crash like that :-) One whole day it was doing it but now seems it's ok, maybe some other problem then. :?
- We are still unable to replicate the crash too, not sure if anyone has this issue.
Braca wrote:Also changing the material name does not change in the working area of hypershade.
- could you please tell us step by step to reproduce?
Ok, new bug found,
whenever I set render image format to EXR, after a while back and forth tuning materials, Octane render changes it back to maya IFF
- We have reported this as a bug?
Thank again!!
Kind Regards
bk3d
Braca
Hey BK,
Chanign material names in Hypershade for some reason now works, I guess it was a Maya issue then.
However here is a video clip of settings changing from EXR to IFF
https://drive.google.com/file/d/1Yv-zwJ ... sp=sharing
Harman
Hey BK,
When I try to make render region in IPR the rendering gets capped at 60 Samples.
Can you solve it?
Harman
Also when I try denoiser output of indirect reflections I get this weird looking image.
Attached screenshot:
BK
Braca wrote:Hey BK,
Hi Braca,
Thank you so much for the video. It is very helpful.
We were able to reproduce it [happens only on Maya 2019.1 and 2019.2 update] and if we leave the Arnold[matao's] as Auto Load enabled/checked.
So, as a workaround please uncheck/disable the Auto load the renderer.
Thanks again!!
Kind Regards
bk3d
BK
Harman wrote:Also when I try denoiser output of indirect reflections I get this weird looking image.
Hi Harman,
Thank you for the post.
could you please provide the steps to reproduce? It may require reloading the scene.
Please try on this new build and see if it resolves the issue [ viewtopic.php?f=109&t=72463 ]
Cheers :)
Kind Regards
bk3d
BK
Harman wrote:Hey BK,
Can you solve it?
Hey Harman,
Thanks again!!
Do you mean the Region render get stuck on 60 Samples?
Please try the new release and let us know how it goes.
Kind Regards
bk3d
Locked
Return to “Releases”
