OctaneRender for Maya 2019.1rc3-15.5 [OBSOLETE]
Forum rules:
NOTE: The software in this forum thread is not 100% reliable, this is a development build and is meant for testing by experienced octane users. If you are a new octane user, we recommend to use the current stable release.
!!! THIS IS THE BETA VERSION OF OctaneRender PLUGIN, IT IS RELEASED FOR INITIAL BUG HUNTING ONLY !!!
!!! PLEASE DON'T USE IT FOR PRODUCTION & DON'T SAVE THE SCENES FROM THIS BETA VERSION FOR FUTURE USE AS THERE ARE HIGH CHANCES TO LOSE THEM !!!
!!! SCENES SAVED IN THIS BETA VERSION ARE NOT GUARANTEED TO WORK IN SUBSEQUENT VERSIONS !!!
!!! THE RENDER ENGINE IS YET TO BE STABLE, SOME CRASHES & BUGS ARE EXPECTED FOR THIS TEST VERSION OF THE PLUGIN !!!
Otoy® is proud to announce the availability of a new test version of OctaneRender™ for Maya® Version 2019.1
Maya® Version Requirements
This release will work with Maya® Versions 2016.5, 2017, 2018 and 2019 64-bit on Windows, Linux and OSX operating systems.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changelog and the installers for Octane Standalone 2019.1 are here:
OctaneRender Standalone 2019.1 RC3
Changes since version 15.4:
  • Integrated the 2019.1 RC3 rendering engine.
KNOWN ISSUES:
  • The new up-scaling feature sometimes fails to render correctly, sometimes with GPU crashing. This is the Octane engine bug.
  • CUDA errors happen often... These are the Octane engine bugs.
  • Due to some inconsistency on the rendering engine level the builtin-scriptgraph nodes are not going to be present in the plugin. At least at this stage.
Subscription Studio Downloads
OctaneRender for Maya Studio [Windows]
OctaneRender for Maya Studio [Linux]
OctaneRender for Maya Studio [MacOS]
Subscription Enterprise Downloads
OctaneRender for Maya Enterprise [Windows]
OctaneRender for Maya Enterprise [Linux]
OctaneRender for Maya Enterprise [MacOS]
Downloads for users with a regular V4 license
OctaneRender for Maya [Windows]
OctaneRender for Maya [Linux]
OctaneRender for Maya [MacOS]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
OctaneRender for Maya DEMO [MacOS]
Jolbertoquini
Hi Jim,
Can we gave a update on the engine Beta with the 2019XB2.2 cause this old one doesn't work anymore
cheers.
Jo
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
hgarrou
Isn't that the worst?
Take your time, do your best work.
Braca
This build is crashing Maya every time I try to put an *.exr image in the environment->octane image
But when I change the output format to EXR and open IPR before adding environment, then go to environment and add the image it is working.
BK
Jolbertoquini wrote:Hi Jim,
cheers.
Jo
Hi Jo,
Thank you for reporting this.
We will try to publish another build by early next week.
Thanks again!!
Kind Regards
bk3d
BK
hgarrou wrote:Isn't that the worst?
Thank you Hgarrou!! :)
Kind Regards
bk3d
BK
Braca wrote:This build is crashing Maya every time I try to put an *.exr image in the environment->octane image
Hi Braca,
Thank you so much for the post.
Would you please attach the crash log file? We are unable to replicate the crash or is it possible to attach a sample file without the .exr image file.
Kind Regards
bk3d
Braca
BK, funny part is now I cannot make it crash like that :-) One whole day it was doing it but now seems it's ok, maybe some other problem then. :?
Braca
Ok, new bug found,
whenever I set render image format to EXR, after a while back and forth tuning materials, Octane render changes it back to maya IFF
Braca
Also changing the material name does not change in the working area of hypershade.
Locked
