OctaneRender™ 2019.1 RC3
mojave
funk wrote:CUDA crash when enabling rounded edges + texture displacement
1. Load orbx and click the render target to start rendering
2. Select the mat1 nodegraph
3. Set rounded edges mode = accurate
Cuda crash:
Started logging on 07.08.19 04:37:33
OctaneRender Enterprise 2019.1 RC3 (6000004)
CUDA error 700 on device 0: an illegal memory access was encountered
  -> failed to wait for event
device 0: path tracing kernel failed
Thank you for the report, we will look into this and fix it in the next release.
haze
PolderAnimation wrote:I have a setup that uses vertex displacment and a texture for the color input.
Why is it that when I change the UV transform scale of the color texture, that octane has to calculate for a minute before I see my result. When I disable the displacement, the changes are instant.
Fixed for next release.
funk
Universal material + emission bug
Something seems to be broken with emission on the universal material. Its OK in 2019.2 XB1, so I assume you already know about it, but I'm posting here just in case
1. Load the attached orbx and select render target
NOTE: The cube should be emissive, but it isnt
2. Select "box" nodegraph and set specular color to 0 (or coating to 1, or transmission to 1)
NOTE: Emission starts working again
universal_emission_broken.orbx
(73.2 KiB) Downloaded 276 times
haze
funk wrote:Universal material + emission bug
yes already fixed.
J.C
Cuda crash:
The attachment displacement_rounded_edge_crash.png is no longer available
This happens with simple scene with VDB objects too.
CUDA error 700 on device 1: an illegal memory access was encountered
device 1: path tracing kernel failed
  -> failed to allocate device memory
clouds_export.orbx
(2.29 MiB) Downloaded 307 times
System – Windows 11
mojave
Cuda crash:
Thank you. This will also be fixed in the next release.
funk
Universal material / transmission bug
The first 3 transmission models dont seem to change anything unless you have an albedo texture plugged in.
Something isnt right here, because when you add a black (0) albedo texture, it changes the appearance. Black and disconnected should look the same.
1. Load the scene and render the universal material
2. Switch transmission model between octane / beckmann / ggx
NOTE: Nothing changes
3. Disconnect the albedo texture and repeat step 2
NOTE: now the material is changing
UPDATE: If you disconnect the albedo again, adding coating or specular color prevents the transmission from working too
universal_trans_model_albedo_bug.ocs
(36.17 KiB) Downloaded 322 times
funk
Denoiser bug:
The denoised version of this material is brighter.
denoise_brighter.ocs
(39.19 KiB) Downloaded 291 times
wallace
funk wrote:Universal material / transmission bug
This is expected, because if albedo (diffuse) is not present, then the transmission layer and the specular layer essentially becomes a specular material on its own, and so it uses the same model as the one specified by "Reflection model".
It's only if there is diffuse layer separating the specular reflective layer on top of it and the specular transmission layer below it that we allow changing the 3 specular transmission models.
wallace
funk wrote:Denoiser bug:
I have fixed this and this will be in the next version.
