Cinema 4D version 2019.1-RC3_r2 (Test build) - 16.08.2019
Kalua
Metallic shaders doesn't seem to have the specular map working coorrecly. No matter how much I slide the amount, the shader wont respond neither in preview or liveviewer.
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
jayroth wrote:Hi Ahmet,
Is displacement mixer limited to vertex displacement only?
Appearently yes. It's named as vertex displacement mixer
jayroth
It does? The node just says Displacement Mixer. No vertex in the name that I can see... :)
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
natemac00
Any C4D example files for the new Material Layer node?
______________
Nate Mac - Chicago, IL
Cinema 4D R26.107 | Octane 2021.1.6
Main: AMD ThreadRipper | Win10 | 32-core | 128GB | RTX A5000 & GTX 2070 SUPER
Slaves: 4x GTX 980 Ti | GTX 1080 | GTX 1070 | GTX 1070Ti
I've actually used a short name.
ralf_breninek
@aoktar: Thanks for all your great work.
Just wanted to say I am super excited for the next release making use of RTX :D
As soon as that one is out and the performance gains are at least x2 (it has been shown to be 3-7 fold depending on the scenes) I am also going to make a switch from v4 to annual subscription. Otherwise I currently do not really need an upgrade, to be honest Octane v4 already has 90% I really need thanks to you and your team ;-)
I am leaving this feedback here to give some customer insight as this is sometimes hard to capture.
C4D R21.207 / Octane for C4D 2020.2.4 / Watercooled 4 x EVGA Geforce RTX 2080 ti
http://www.pixelasm.com
Interface and motion graphics design for interactive interfaces and animations on TV, web, mobile and automotive from Köln / Cologne Germany
sdanaher
Normalise lights seems to be broken.
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
ralf_breninek wrote:@aoktar: Thanks for all your great work.
Thanks to Otoy also! RTX will be on 2019.2 if we there's not any problems
Ron
What could be the reason for this orphaned node when using a material from Live-DB?
And the GUI color of this node seems to be wrong, isn't it?
Thanks - Ron
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
Kalua
Ron wrote:What could be the reason for this orphaned node when using a material from Live-DB?
Thanks - Ron
The attachment Orphaned_Node.jpg is no longer available
Speaking of wrong node colors:
Can´t remember since what version several nodes have mismached color node code. I have always forgoten to report this because is not really critical. Since it was mentioned now I also report it.
This picture is from v 2019 in R20 but the "mismatch" is also present in 2018 and possibly in previous versions.
Return to “Releases”
