OctaneRender™ 2019.1 RC2
haze
Dear all,
This is an update to 2019.1 with some additional fixes.
We still consider this an experimental build, until we leave the RC status. Please don't use this for production purposes.
Please also ensure that you have a NVIDIA driver version 419.x or newer.
Changes since OctaneRender 2019.1 RC1:
  • Minor performance improvements
  • Fixed AI light darkening images, improved stability
  • Improved info channel kernel speed
  • Fixed render failure when enabling shadow catcher inside a diffuse material under a layered material
  • Removed dielectric/coating layers and turned dielectric layer into specular layer again
  • Fixed universal/layered materials rendering some passes incorrectly when there is diffuse+specular, vs glossy material
  • Fixed universal material coating causing the specular layer to be ignored
  • Fixed universal material rendering incorrectly when transmission is white, albedo is black, and reflection model is GGX
  • Fixed coating layer rendering incorrectly when roughness is zero
Downloads
Downloads for users with an Enterprise subscription license
OctaneRender Enterprise 2019.1 RC2 (Windows installer)
OctaneRender Enterprise 2019.1 RC2 (Windows zip)
OctaneRender Enterprise 2019.1 RC2 (Mac OS)
OctaneRender Enterprise 2019.1 RC2 (Linux)
Downloads for users with a Studio subscription license
OctaneRender Studio 2019.1 RC2 (Windows installer)
OctaneRender Studio 2019.1 RC2 (Windows zip)
OctaneRender Studio 2019.1 RC2 (Mac OS)
OctaneRender Studio 2019.1 RC2 (Linux)
Downloads for users with a regular V4 license
OctaneRender 2019.1 RC2 (Windows installer)
OctaneRender 2019.1 RC2 (Windows zip)
OctaneRender 2019.1 RC2 (Mac OS)
OctaneRender 2019.1 RC2 (Linux)
Happy rendering
Your OTOY NZ team
funk
Thanks OTOY
I see the glossy material no longer becomes 100% reflective when IOR = 1 (EDIT: It works for octane BRDF, but not for ggx/ward/beckmann).
This is going to break some old material presets / scenes we may have that rely on this behavior.
One of the reasons I would like this fixed is because it allows you to create a colored "metal" without fresnel. The metallic material always has an achromatic schlick's fresnel.
If the change is intentional, then please add a 1/IOR texture pin, so we can at least manually set this to a greyscale of 0.01 to get a mirror surface.
Notiusweb
Pickers (Focus, White Balance, Material, Object, Camera-target) with up-sampling still aren't working in this version either.
Pickers worked in 2019 XB2 (which had up-sampling), not working in 2019 RC1 and RC2.
THX
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
wallace
funk wrote:Thanks OTOY
This is not intentional, I will put a fix for this.
funk
wallace wrote:This is not intentional, I will put a fix for this.
Thanks wallace
funk
I have an old orbx which is rendering darker mediums in 2019.1 compared to 2018 and 4.
medium_darker.orbx
(141.79 KiB) Downloaded 315 times
funk
Otoy team,
When we enable the denoiser, viewport interactivity slows down. Is it possible to look into this?
Someone posted an example video (in modo) here: viewtopic.php?p=365499#p365499
video: https://www.mediafire.com/file/kbag4c1t ... g.mp4/file
I have attached the exported ORBX to this post
1. Load IPR Speed Test_house.orbx and click the render target
2. Quickly pan the view with right mouse. It feels smooth and interactive.
3. Select the camera imager and enable the denoiser
4. Pan the view with right mouse. It now feels much slower.
You can also test it with a simpler scene:
1. Grab "Fun_With_Vectron (4).orbx" from this post: viewtopic.php?p=357928#p357928
2. Click "Vetcron Shadertoy Primitives" and pan the view with right mouse. It feels smooth and interactive.
3. Select the camera imager and enable the denoiser (you'll need to add the bool)
IPR Speed Test_house.7z
(2.78 MiB) Downloaded 325 times
slow_viewport_denoiser.mp4
(3.8 MiB) Downloaded 7253 times
funk
Layering bug? Diffuse material + diffuse layer opacity is not working as expected. (happens with other material layers too)
1. Load orbx and start render
2. Select the "test" material group and adjust the DIFFUSE LAYER opacity from 0 through to 1 slowly
When you go from 0 to 0.01, there is a drastic change from a darker color to a light one.
diffuse_diffuse_layer.orbx
(147.46 KiB) Downloaded 322 times
funk
Composite/Layering bug?
I'm mixing 2 materials here with a 0.5 mask. If I swap the 2 material composite inputs, I should get exactly the same result, but I dont.
1. Double click the "test" nodegraph group
2. Swap the 2 composite inputs around
composite_mixing_unexpected.orbx
(150.89 KiB) Downloaded 333 times
funk
Composite / fake shadows bug?
Plugging this specular material into a composite, makes it darker. I think it's related to the specular fake shadows option
composite_makes_specular_material_darker.ocs
(38.08 KiB) Downloaded 342 times
