Getting yellow buckets on large render
sdanaher
Some buckets on a big image are rendering yellow (blue channel is missing, red channel is affected but not as much). Happens on frame sizes over 10k px.
At 10k * 7k px it renders fine but at 13k * 9k px and above it produces these incomplete buckets.
Octane 4.04 R2
Cinema R20.059
imac 5k 10.13.6, 40GB, + eGPU Titan X (host)
Network PC with 2x RTX 2070
GPU memory usage ~1.5GB
Cinema's RAM usage is 30GB at 10k px and about 40 GB for 15k px during rendering not sure if this is relevant.
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
Please report it in standalone section. It's not a plugin issue and nothing to investigate by plugin devs.
sdanaher
ok thx
sdanaher
BTW can you do something about the corrupt display of info on large frames Ahmet?
sdanaher wrote:BTW can you do something about the corrupt display of info on large frames Ahmet?
I haven't see it before. What happen if you render a SIMPLE scene at SAME resolution without NETRENDER?
sdanaher
Happens all the time here. The bigger the frame the worse it is - on smaller frames its the end of the NetRender line that gets covered over.
Just tested without Net Render, simpler scene, same thing. 15x10k px frame.
