OctaneRender 4 for DAZ Studio [TEST and STABLE] [OBSOLETE]
Moderator: BK
itou31
That will be cool ! Thanks Paul.
I7-3930K 64Go RAM Win8.1pro , main 3 titans + 780Ti
Xeon 2696V3 64Go RAM Win8.1/win10/win7, 2x 1080Ti + 3x 980Ti + 2x Titan Black
wader
Hi face_off, a quick bug report that is easy to reproduce on my system - the Octane plugin claims "Bogus scene path" when trying to open texture files that have an apostrophe in the pathname:
viewtopic.php?f=44&t=71953&p=365397#p365397
If you work with the same pathname reference while editing the file, the plugin has no problems using that pathname in the material. This error only happens when opening the scene.
Windows 10 Pro 64-bit | Ryzen 9 5950X | ASUS Pro WS X570-ACE | 64GB |{ASUS ROG Strix GTX 3090 24GB + (2x) Titan X Pascal 12GB}
I have escalated this issue to OTOY (since it appears to be an issue with the Octane API) and will let you know when I get a response.
DigitalPanther
I have attempted to install the Daz Studio plugin for Octane 4.02.1.44 for use with Daz 4.11.0.383 on Windows 10 with all current updates and it goes through the process and even activates. but when I open Daz the plugin is nowhere to be found. I have confirmed it is going into the correct folder (my daz is installed in D:\3D\Daz3D\Daz Studio 4\ )
Daz was not running when I did then install.
I even rebooted and ran the installer for the plugin as the first task after Windows came back up.
Pressing F12 does nothing. It doesn't show up under window>panes (tabs)>
Are there known issues with this build of Daz? or the plugin?
-DP
The plugin won't load unless you have recent Nvidia drivers installed. To check this, install and render with Octane Standalone. If it renders, the DAZStudio plugin should run.
DigitalPanther
face_off wrote: The plugin won't load unless you have recent Nvidia drivers installed. To check this, install and render with Octane Standalone. If it renders, the DAZStudio plugin should run.
I have the most current Nvidia drivers. Fresh installed this afternoon (after the initial install of the plugin. ) I have rebooted and fired up Daz again and the plugin still isn't loading.
I also have the plugin for Poser 11 and it is working fine with Poser.
I don't know how to pull a poser or daz file into the stand alone renderer. I apologize for my lack of knowledge there.
-DP
P.S.
Is it just me or did the Daz version of the plugin get more love than the poser one. It interface is much nicer (based on the docs. I haven't seen it up yet due to the above not loading issue.)
OK, sounds like it's not a drivers problem then. Can you post screenshots of the DAZStudio Render menu, and the D:\3D\Daz3D\Daz Studio 4\ folder in Windows Explorer in date order (so octane.dll should be at the top).
DigitalPanther
[quote="face_off"OK, sounds like it's not a drivers problem then. Can you post screenshots of the DAZStudio Render menu, and the D:\3D\Daz3D\Daz Studio 4\ folder in Windows Explorer in date order (so octane.dll should be at the top).
Paul[/quote]
Thank you for your time on this it is really appreciated.
I have grabbed the requested screenshots as well as a shot of the window>Panes(tabs) menu where the docs said I should find the octane renderer.
Install folder
Install folder
Render window
Render window
Daz Window>Panes(tabs) menu
Thanks. I notice that the octane.dll date is 11-Feb. Which version (ie. filename) have you installed please? Have you tried the latest release?
DigitalPanther
face_off wrote:Thanks. I notice that the octane.dll date is 11-Feb. Which version (ie. filename) have you installed please? Have you tried the latest release?
I installed 4.02.1.44. I tried pulling down the 2018.1.0 but it won't authenticate because I don't have a subscription.
My license is for the non subscription version.
-DP
Return to “DAZ Studio”
