Substance Plugin with Octane
MrFurious
Has anyone managed to get this working? Seems to have an issue with the Basecolour and Normal outputs not rendering properly. Other outputs work though, such as AO, Bump, Metallic, roughness.
Dino Inglese
CG Artist
Melbourne Australia
Intel Core i7-4820K, 3x GTX 980ti
Windows 7 64bit, Modo 12.2v2 for PC
Octane build 4.04.0.145
Dino, can you provide more details on this, such as the Octane plugin and substance versions you are running, the Modo version, and what you mean by "not rendering properly".
MrFurious
Thanks Paul, I'm running...
Modo 12.2 v2
Octane Plugin 4.02.1.140
SubstanceInModo 2.7.0/ddf7503
I downloaded this sbsar file from the SubstanceShare website and added it to a ground plane in modo:
Abandoned_Hotel_Marble_Floor.7z
(146.83 KiB) Downloaded 279 times
Modo's render looks correct:
The octane render looks ok until the normal and basecolour outputs are added. I've added the outputs one at a time:
AO
AO + Height
AO + Height + Spec / Metal
AO + Height + Spec / Metal + Rough
AO + Height + Spec / Metal + Rough + Normal
AO + Height + Spec / Metal + Rough + Normal + Basecolour
The Normal and Basecolour outputs aren't mapping correctly. I've had the same issue with most of the materials from SubstanceShare, although a couple look fine.
Seems some others are having the same issue here, which was last updated 18th December 2018:
https://forum.allegorithmic.com/index.php?topic=6125.45
I suppose this could also be an issue with the SubstanceInModo plugin, I'll reply to the allegorathimic forum to see if there's been any news.
Cheers,
Dino.
Dino Inglese
CG Artist
Melbourne Australia
Hi Dino
I am using Substance 2.4 and could not reproduce these issues, so I suspect there might be an issue with the 2.7 version of Substance.
MrFurious
Thanks. What version of modo/octane are you having success with the substance plugin v2.4?
Dino Inglese
CG Artist
Melbourne Australia
Hi - I have now tested this on Substance 2.7, and yes, the normal map appears to be not working, and I have had the diffuse map working sometimes, not others. I have reported this to the Substance devs.
MrFurious
Thanks Paul, I've had the exact same experience; normal map doesn't work but sometimes the diffuse or main input works. Would I be correct in assuming that the v2.4 substance plugin doesn't work with modo 12 &/or the latest octane for modo plugin?
Dino Inglese
CG Artist
Melbourne Australia
I'm not sure - sorry Dino. I will prod the Sbnstance devs about this issue again.
LFedit
Glad I finally decided to search for this.. My normal maps aren't working. Same setup, Modo 12 Substance 2019.1.2
Also, when I use the substance plugin, I create the substance, then thats pretty much all the plugin does. I don't get anymore options anywhere else.
Win 10, Threadripper Pro, Dual 3090s
villagefeatures
I'm having similar issues as well though my substance files do not render at all. I'm on Modo 13.0.1 and Octane 2018.1.3.145
Return to “Foundry Modo”
