Cryptomatte passes don’t seem to render correctly in Octane Blender 2018.1 / 17.6. When I bring the files into After Effects, the Cryptomatte plug in doesn’t detect them.
However, if I take the same Octane Blender file and export scene to ORBX and render in stand alone, the Cryptomatte passes show up fine. See attached screen shots.
Attached is blend file, ORBX export, and rendered EXR files.
Cryptomatte issue
C. RAM Capacity (i.e. 6 GB)
- Cryptomatte-Issue.zip
- (2.59 MiB) Downloaded 323 times
Win 11 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
I've checked this and this is not working in Blender :/
System – Windows 11
System – Windows 11
- linograndiotoy
I can confirm that as well.J.C wrote:I've checked this and this is not working in Blender :/
It has been reported and it will be fixed as soon as possible!
Thanks Pegot and Bartek!
Thanks for your report and sorry for the inconvenience.
This is due to the cryptomatte channels are different from the colorful image. They are actually pairs of int and float channels, each giving you a material ID and an amount of coverage. Blender 2.79 cannot recognize such formats so the export fails. As workarounds, we will export render passes(include crypto) as exr via octane sdks to the blender output path.
Cheers,
DrawFun
Cheers,
DrawFun
Hi DrawFun,
Can you elaborate this workaround? How are we going to use this?
DrawFun wrote: ...As workarounds, we will export render passes(include crypto) as exr via octane sdks to the blender output path.
System – Windows 11
System – Windows 11
In 17.9 Cryptomatte passes are saved in OpenEXR Multilayer file. As we know these are not being saved correctly and are useless. Correct Crypto passes are created in a separate file.
System – Windows 11
System – Windows 11
Empty Cryptomatte files are created when none of the crypromatte passes are selected. Please disable this. This is waste of disk space.
System – Windows 11
System – Windows 11
