Hi guys,
I've encountered a weird crash, it's hard for me to troubleshoot as it's a really simple scene - cloners with displacement & moving camera, I'm using some x-particles (not too heavy) and AI denoiser. The render runs fine for around 30-40 frames and then it crashes. I'm rendering the animation to PV. I can continue rendering after restarting the application.
My specs are:
Win 10
GTX 1070
64GB
419.67
Latest Octane for C4D
C4D r20
I've attached the bug report
Crash every 30-40 frames when rendering
C. RAM Capacity (i.e. 6 GB)
- _BugReport.txt
- (558.34 KiB) Downloaded 242 times
I can see it's renderer level crash. How hard to share a sample scene for showing the issue to us? And writing the version numbers with respect to request? We cannot know numbers from "latest stable".
Sure not a problem if it helps, attached below.
Octane 2018.1.3
Octane 2018.1.3
- circuit.zip
- (7.12 MiB) Downloaded 278 times
No crashes on me as usual. Probably you're out of ram/vram. Could you render your scene after activated the all log options from "SETTINGS/OTHER/LOG OUTPUT"? And send your "c4doctanelog.txt". It will record most of data to invistigate.dephixeb wrote:Sure not a problem if it helps, attached below.
Octane 2018.1.3
I made few more tests yesterday throughout the day (so the file is a a little big), but in the end I managed to render up to 99 frame until it crashed, at 19:37
- c4doctanelog.txt
- (62.8 MiB) Downloaded 337 times
- 3DTreatment
has this problem been solved? I am having the same crashes. Turning of motion blur and denoiser helped a little but I still have a lot of crashes.
- Deltaproxy
Hi, having the same problem..
Cinema4D - Application Error - crash after 11-25 frames at any render with any scene,
both from Cinema 4D plugin and Octane Stand alone (both version 2018.1.3)
I have no plugins nor special textures in my scene.
2x2080ti
i7 6900k
64 GB RAM
Win 10
Please let me know if you have any solution thanks
F
2x2080ti
i7 6900k
64 GB RAM
Win 10
F
- octane 2018.1.3 190920 011324.log
- (6.11 KiB) Downloaded 211 times
Use latest STUDIO drivers not Game Ready drivers, don't use overclocking. Check VRAM/RAM and temperatures of your system while rendering.Deltaproxy wrote:Hi, having the same problem..
2x2080ti
i7 6900k
64 GB RAM
Win 10
F
- Deltaproxy
Yes! that sorted things out. Thanks a lot!
F[/quote]
Use latest STUDIO drivers not Game Ready drivers, don't use overclocking. Check VRAM/RAM and temperatures of your system while rendering.[/quote]
F[/quote]
