Lua scripts in Octane Instance openned from Unity
Unity Integrated Plugin (Integrated Plugin maintained by OTOY)
Moderator: ChrisHekman
mmortall
I was trying to run some lua scripts in Octane Instance opened from Unity Octane Plugin.
But I got errors when running any script. I got Script error related to octane.nodegraph is nil and octane.gui is nil. So I'm not able to use scripts at all.
Is there a limitation to use Lua script in Octane Instance from Unity? Because I see the Script menu item and a way to run them.
Her is my script test code:
dialogProperties =
	type  = octane.gui.dialogType.ERROR_DIALOG,
	title = "Test Title",
	text  = string.format("Test Text")
octane.gui.showDialog(dialogProperties)
scene = octane.nodegraph.getRootGraph()
mmortall
Hi. It there any news about it? Thanks
tombube
Hi, any news about this? We currently avoid using lua scripts inside Octane Unity and always export to an ORBX file to run lua scripts on, so it would be useful to have official support for running scripts inside Unity Octane instance (and also an option to start the Lua script using C#)
Return to “Unity”
