Material mix node request
grimm
Hi Guys,
I have been playing with the material nodes and it's very nice. I would like to make one request though. It would be great to have a material mix node that give you a bit more control over how the materials are mixed together. One method I was thinking about would be to have a mix node just like the ones you already have. The difference would be that you have two slider nobs/handles instead of one. It would work like this:
The area from the start of the slider to the first handle would be 100% of material A
The area from the second handle and the end of the slider would be 100% of material B
The area between the handles would be a linear mix of both materials.
Does this sound feasible? Or is it already in the works? Thanks, :)
Grimm
matej
To achieve this create a texture and plug it as amount parameter of mix material.
Ofcourse it would be useful to have a color ramp generator in the future.
cgmo.net
grimm
Thanks Matej,
I'm not quite sure what you meant in your post. Is there a chance you could post an example? I tried hooking up the mixing nodes in as many configurations that I could think of but they didn't do what I wanted. Thanks,
Grimm
matej
grimm wrote:Thanks Matej,
Grimm
You create the color ramp in your image editing software:
And map it to amount:
Ofcourse the texture doesn't fit nice on the preview ball, but it will on your properly UV-mapped object
cgmo.net
grimm
Ah, cool I see. Not quite what I wanted though. I want to be able to control the mix with a procedural node. And I don't want to have to worry about doing a UV unwrap on the mesh. That's the fun thing about procedurals. :) Thanks though, that's a good idea.
Grimm
grimm
Yes that would be helpful, but only if the node had an additional input for noise or turbulence. Maybe it would be better to think of what I would like as a re-mapping node that can take an input and map it to a gradient/ramp values with dual (or more?) controls.
Grimm
