Rhino 6 SR14 (latest) Render preview broken
Forums: Rhino 6 SR14 (latest) Render preview broken
Postby reberts2 » Tue May 07, 2019 8:45 pm
reberts2 Tue May 07, 2019 8:45 pm
I am running the latest revision of Rhino, Octane 4 and Octane plugin for Rhino and noticed that
Rendered viewport preview is broken - everything shows dark grey, not color, no textures etc.
Any thoughts?
Win 7 64 | GTX260 x 2 | Core i7 860 | 4GB & OSX 10.6 | 8600M GT | Core 2 Duo | 4GB
reberts2
Re: Rhino 6 SR14 (latest) Render preview broken
Postby face_off » Wed May 08, 2019 8:19 am
face_off Wed May 08, 2019 8:19 am
Hi. From your description I cannot tell exactly what is happening. Can you provide some screenshots please?
Postby reberts2 » Wed May 08, 2019 12:48 pm
reberts2 Wed May 08, 2019 12:48 pm
Yes, thank you.
I am observing 2 things since I updated to the latest Rhino 6 and Octane releases;
1. The viewport does not simulate material color/textures anymore (it did so very briefly one time) - everything appears grey as in attached screenshot.
2. The Octane rendering does not render mapped textures correctly - to work around I had to recreate all textured materials as Rhino materials, then convert them to Octane, and they correctly rendered (however I still cannot preview them in the viewport).
The material previews sometimes also do not render.
Thank you for your assistance.
Sincerely,
Rick
reberts2
Postby face_off » Wed May 08, 2019 1:39 pm
face_off Wed May 08, 2019 1:39 pm
Can you send me a scene which demonstrates these issues please?
Postby reberts2 » Wed May 08, 2019 3:21 pm
reberts2 Wed May 08, 2019 3:21 pm
Yes Paul.
Thank you,
Rick
reberts2
Postby reberts2 » Wed May 08, 2019 6:16 pm
reberts2 Wed May 08, 2019 6:16 pm
Also forgot to note the following behavior Paul, which is new to my Octane experience;
Open the file and click the Materials tab - no details on materials, regardless of material selected.
Just white space (screenshot attached).
-Rick
reberts2
Postby reberts2 » Wed May 08, 2019 6:33 pm
reberts2 Wed May 08, 2019 6:33 pm
Paul,
I just tried the same trick of flipping over to the Octane tab and converting all Rhino materials to Octane (they were already Octane),
and the details for each material appeared as normal when selected?
Rick
reberts2
Postby face_off » Thu May 09, 2019 5:19 am
face_off Thu May 09, 2019 5:19 am
Yes - you need to open the Octane tab before you can view OctaneRender materials in the Material tab. The nexty version of the plugin pops a warning message to tell you this.
Thanks for providing the sample file. I think this is happening because of the same reason above. If you click on the OctaneRender tab prior to loading the scene, the Rhino Rendered viewport seems to pick up the textures. I will see if I can find a solution.
Postby reberts2 » Thu May 09, 2019 12:43 pm
reberts2 Thu May 09, 2019 12:43 pm
Excellent, thank you Paul.
Thanks for your ongoing work to improve the plug-in.
-Rick
reberts2
Return to Rhinoceros 3D
Tue Jun 04, 2024 7:01 pm [ UTC ]
