Alpha shader development - Pixel failure
Taksha
Hello together,
The mysterious thing for the first: one time i open up the c4d file with the native shaders from c4d, activated octane and the firts render looks like my old shader is nearly compatible.
I was so lucky to open it without big changes and thought: "Yeah, better compatiblity as expected" - but now i got the opposit.
The next time i open it up it does not recognize the original state like before :( - only some elements was looking like the original c4d scene.
I am new to Octane and now i have to make some of my shaders in octane again to have the best results.
Because the converter did not made it like it should.
So i have to make my alpha shader trix again. They worked very nice as Cinema 4D shader.
But conversion was not like the original. I started from scratch. I made the first version ready in Octane.
But now i see that there is a line of pixels at the gap where the texture loop is closing - and i can not get rid of it.
I exported the scene to Octane Render 2018.1.2 - sadly i saw it there too.
See my pics attached, you can see the line of pixels that normallly should not be there at the gaps - the sphere primitiv got it too..
The old c4d shader where this shader was originally made, was renderd without this pixel failures.
I saw that thisline of pixels can be seen in other alpha shaders i loaded from LiveDB too.
So i guess it is very important to inform about and hopfully can be fixed easily.
May be someone got a work around for this?
Have a good day, best regards
unfortunately the image is not visible, please share with me an example scene with assets, here or via PM, thanks.
C4D shaders are only partially supported, and auto-baked on the fly, so not ideal, especially for mid/complex scenes.
Always better to use Octane shaders for best quality, stability and speed.
ciao Beppe
Taksha
Hey thank you, I made a test to see if it appears in octane shader too - yes it does - I tried some shaders with alpha from the Live DB.
I will send some examples asap.
Workstation X3: WIN7 - 2x Xeon E5 | 64 GB | 2x RTX 2080ti
______
Hackintosh: WIN7/ OS X 10.8.5/ macOS 10.13.6 running Octane :) - 1x i7 4770K | 32 GB | 1x GTX 980ti
Taksha
Sorry for my late response!
Pixel on bounds that should not be there - part 1
Here you can see 2 issues: The mysterious Pixels that occur on boundries / edges when objects meet. And a loading failure...
In this test example the pixel failure show up without displacement - shaders taken from Live DB.
______
Taksha
Macro - the slice becoming visible on invisible borders from the alpha shader object - without displacement the pixel failure does not show up in this example.
Unwanted Pixel part 2 - Here are another strange behaviour with displacement and touching objects.
The Alpha is generated from a File in the opacity channel of the shader.
______
