OctaneRender for Maya 2018.1.2-14.30 [OBSOLETE]
Moderator: JimStar
Locked
JimStar
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya® Version 2018.1
Maya® Version Requirements
This release will work with Maya® Versions 2016.5, 2017, 2018 and 2019 64-bit on Windows, Linux and OSX operating systems.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone 2018.1.2
Changes since version 14.29:
  • More improvements of the translation system to support animated OSL-dynamic attributes.
Subscription Studio Downloads
OctaneRender for Maya Studio [Windows]
OctaneRender for Maya Studio [Linux]
OctaneRender for Maya Studio [MacOS]
Subscription Enterprise Downloads
OctaneRender for Maya Enterprise [Windows]
OctaneRender for Maya Enterprise [Linux]
OctaneRender for Maya Enterprise [MacOS]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
OctaneRender for Maya DEMO [MacOS]
Jolbertoquini
Hi Jim,
How to make work the node with the color vertex node??? here a screenshot of my screen, I add the name and doesn't work at all. Did I made something wrong?
Cheers,
JO
Color_Vertex.zip
Maya scene
(118.52 KiB) Downloaded 195 times
Vertex color
Vertex color
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
calus
Jolbertoquini wrote: How to make work the node with the color vertex node?
You just need to fill out the name of the colorset in the new "vertex attributes" section.
- Adding the colorset name in a "Color attribute" fileds will extract RGB color.
- Adding the colorset name in the "float attribute" fields will extract by default the alpha component of a maya RGBA colorset,
or you can be specifically add ".r", ".g", ".b" or ".a" at the end of the colorset name.
Pascal ANDRE
Jolbertoquini
Thanks Pascal! Little hide extra data I thought to put the name just on the node would be enough like for upsets but never mind thanks to point out this.
Cheers,
JO
Locked
Return to “Releases”
