I'm testing some OpenVDB smoke sequence a coworker simmed in Blender. I'd like to render it in LightWave with Octane.
I can't seem to figure out how to render the sequence!?
I load the first frame, but it renders that frame only through the entire 250 frames. It won't load and progress through the frames unless I manually go into the Octane Volumetric panel and select a different frame.
How do I render a VDB sequence?
I first used Blender to create a fire effect, but my cache file looks like Fire_000400_00.vdb - how do I rename or re-save a sequence with fewer characters so I can use animation in Octane?
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
Lightwave 3d
What are the digits on this filename used by the sequence? The 000400 or the latest 00 ....promity wrote:I first used Blender to create a fire effect, but my cache file looks like Fire_000400_00.vdb - how do I rename or re-save a sequence with fewer characters so I can use animation in Octane?
In the first case, you could use Fire_00$F_00.vdb, if you file is the frame 400. If not, you can use a renamer tool, like this one to rename the sequence:
https://www.advancedrenamer.com/
The client sent me a VDB sequence that I should use in the animation. But I’m completely confused - I totally don’t understand the algorithm for working with VDB sequences in Octane+LW.
This is what the first file in this sequence looks like - Default_0001.vdb. Should I rename it and how should it look after renaming? Should sequence files contain $F characters in their name? Will it ever be possible to use volumetrics based on embedded lv tools without having to memorize all sorts of tricks for using VDB volumetrics?
P.S. This is gaseous volumetrics (explosion) so I can not use OpenVDB Evaluator tool.
Lightwave 3d
Lightwave 3d
