Displacement wrong placement - any ideas why?
Forums: Displacement wrong placement - any ideas why?
Postby ThomasVandenAbeele » Wed Apr 10, 2019 2:26 pm
ThomasVandenAbeele Wed Apr 10, 2019 2:26 pm
Hi!
I have a displacement behaving weirdly, and I can't seem to figure out why... The attached screenshot shows a circular mapping, with the letter N in the middle. The image is placed correctly in the diffuse channel, but the same texture hooked up to displacement is placed and scaled wrongly.
Does anyone know why it behaves this way?
Thomas
ThomasVandenAbeele
Re: Displacement wrong placement - any ideas why?
Postby promity » Wed Apr 10, 2019 2:48 pm
promity Wed Apr 10, 2019 2:48 pm
Just check if your model have UV texture coordinates.
Asus z9ped8ws/2x Intel Xeon E5-2692 v2/64gb ram/GTX1080+GTX 1070+GTX 980Ti/Samsung SSD 850 EVO 250 gb/
Octaneplugin+Lightwave 3d)
promity
Postby ThomasVandenAbeele » Wed Apr 10, 2019 2:53 pm
ThomasVandenAbeele Wed Apr 10, 2019 2:53 pm
Is that the same Promity from the Kray forum? If so, hi Promity! Nice to meet you here as well ;-)
The model has UV texture coordinates - as is visible from the mapping of the texture on the diffuse channel. Or did you mean something else?
ThomasVandenAbeele
Postby juanjgon » Wed Apr 10, 2019 10:04 pm
juanjgon Wed Apr 10, 2019 10:04 pm
Do you have any kind of transformation in the UV map parameters in the texture sampler node? This could explain this behavior, but if you want to share the scene I could take a look at it.
juanjgon
Postby ThomasVandenAbeele » Thu Apr 11, 2019 7:58 am
ThomasVandenAbeele Thu Apr 11, 2019 7:58 am
Hi Juan,
No transformation in the UV map parameters. However, I discovered the error today: the displacement keeps using UV map 1, even though you specify UV map 2 in the texture sampler node.
This causes the wrong mapping, and the disconnect between diffuse mapping and displacement mapping: the texture sampler is set to use UV map 2, and diffuse uses this correctly, but displacement incorrectly still uses UV map 1.
Is this a known issue? Is there a workaround for this?
ThomasVandenAbeele
Postby promity » Thu Apr 11, 2019 8:20 am
promity Thu Apr 11, 2019 8:20 am
ThomasVandenAbeele wrote:Is that the same Promity from the Kray forum? If so, hi Promity! Nice to meet you here as well ;-)
Yep, hello )
promity
Postby juanjgon » Thu Apr 11, 2019 10:36 am
juanjgon Thu Apr 11, 2019 10:36 am
ThomasVandenAbeele wrote:Hi Juan,
What Octane version are you using? I think that this issue was fixed in the Octane 2018.1, or at least in the latest just released Octane 2018.1.1 ...
juanjgon
Postby ThomasVandenAbeele » Fri Apr 12, 2019 7:21 am
ThomasVandenAbeele Fri Apr 12, 2019 7:21 am
I'm still using version 3, so that explains why the bug is still in there!
But as I understand it, putting the UV for displacement in slot 1 is a perfectly good workaround, right?
ThomasVandenAbeele
Postby juanjgon » Fri Apr 12, 2019 9:17 am
juanjgon Fri Apr 12, 2019 9:17 am
Yes, I suppose that the displacement from the first UV map should always work fine.
juanjgon
Return to Lightwave 3D
Fri May 29, 2020 9:06 pm [ UTC ]
