instant crash when hitting render
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
zawij
A. Operating System, OSX 10.13.6 (17G65)
B. Graphics Card(s) model: MSI GTX1080
C. RAM Capacity (8 GB) / COMPUTER RAM 32GB
D. Nvidia driver version 387.10.10.10.40.105
E. OctaneRender Standalone version, if installed -
F. OctaneRender plugin version 2018.1 R2 (latest stable), but tried with different versions (4 latest stable- same crash)
G. Host application version, including build number if available C4D R20.059 RB272827
When I HIT render in LV or to PV octane and c4d crashes instantly after sending the scene. If it's simple scene (only cube in it), it crashes instantly, when the scene is more complicated (but it works in R19, sends to LV in less than minute), in R20 it crashes after that time.
No matter if I install octane v4 (latest stable), or 2018.1.
Now I reinstalled C4D R20 and updated it, and it crashes again.
My scene (which is only c4d cube) and bug report and screenshot is here:
https://www.dropbox.com/s/gn1pe04bjd9ja ... 3.zip?dl=0
please go to Apple menu, About this Mac, then press the System Report button, then go to menu File/Save, and share the resulting .spx file, thanks.
Which eGPU script have you installed?
ciao Beppe
zawij
Here's my file:
https://www.dropbox.com/s/kerx05jbat2vu ... o.spx?dl=0
I used purge-wrangler.sh script from egpu.io
But the script itself works.. on C4D R19, and it worked for a long time on R20, but something happened since one c4doctane crash a 2-3 weeks ago.
thanks for sharing the .spx file.
It shows that you are working with CUDA 396.148, please upgrade to 410.130, and report back, thanks:
https://www.nvidia.com/object/macosx-cu ... river.html
ciao Beppe
zawij
Now I have:
CUDA Driver Version: 410.130
C4D R19 still works
R20 still does not.
Should I go for CUDA 418.105? IT says in the system prefs its the newest available?
No please, stick to 410.130 CUDA version.
If plugin works in R19, but it doesn’t in R20, probably it is not correctly installed.
Please, share a screenshot of the R20 c4doctane directory with path, thanks.
ciao Beppe
zawij
Here's my screenshot
I believe it is correctly installed while it was working a while ago and stopped without my interference.
Could be this a case of permissions? How to check/correct that?
please, open a scenee, then go to c4doctane Settings/Others tab, and at the bottom of the panel, enable all the Log option checkboxes:
Finally, load the scene in Live View, and share the c4doctanelog.txt file that you find in c4doctane directory, thanks.
Looking forward for your feedback,
zawij
Here's the file.
Hope it helps...
c4doctanelog.txt
(4.32 KiB) Downloaded 255 times
Hi
please, remove the installed version, and try to install in the following directory:
HD\Users_Your Name_\Library\Preferences\MAXON\Cinema 4D R20_random code\plugins\
Please have a look at this installation video for C4D R20:
https://youtu.be/nPjloJ3X7x4
ciao Beppe
Return to “Bug Reports”
