No volume properties in Material tab Surface
C. RAM Capacity (i.e. 6 GB)
Going to > Material tab > Surface rollout does not show Volume shader properties. Doing the same with any other Shader all properties are available.
System – Windows 11
System – Windows 11
Can you show some screenshots?
It's not clear what you're referring to (There is no "Volume Shader" in Octane, and I can't see any issues with mediums in the Material tab).
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Octane Prime - Blender Plugin user
Metal IOR values for Octane (with .blend library): https://chris.hindefjord.se/resources/rgb-ior-metals/
System – Windows 11
System – Windows 11
The Volume input of the Material output node doesn't do anything (neither does the Displacement input).
The Volume input of the material output doesn't have matching node/setup in Octane, you should be able to see this if you take a look at the generated NodeGraph (It will be there, but not connected to anything), and you shouldn't see the result of it in the viewport (right!?). (Also, technically: "Volumes" are called "Mediums" in Octane).
You have to connect your Medium node to a Material/Shader node (like Specular) to use it. (I guess the devs just copied the Output node from Cycles and left "Volume" and "Displacement" there..)
- linograndiotoy
Bartek is right, Volume should show up in the Material tab, since it's actually used to define Smoke and OpenVDB shading.
Thanks for you report, Bartek!
