ORBX export and creation of temp file in Users directory
pegot
When exporting to ORBX Blender Octane creates a temporary Alembic file in Users/User Name/livedb/alembic.
I noticed that after the ORBX is successfully exported to whatever its final destination is (for me a NAS) the ABC is converted to another ORBX file but is not deleted. It stays in the Users livedb directory. When exporting large files – particularly fluid sims - it is not unusual to wind up with 20 – 30 GB ORBX files. Why aren’t these files automatically removed after a successful export? This is a sure way of quickly clogging up ones system drive.
This also brings me to another question: Is it possible to set a different drive where these “temporary” files are created during ORBX export? I recently had an incident where ORBX export failed because my system drive at the time had only 20 GB remaining but the ORBX must have needed more temporary space for completion. Being able to customize the path and drive where these files are created during ORBX export would elevate such situations.
Please let me know if this functionality currently exists, or if I should put it in as a feature request.
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
J.C
Reported it again:
viewtopic.php?f=114&t=71165
System – Windows 11
DrawFun
Hello,
Thanks for your reports. We will add this feature in the next build.
Cheers,
DrawFun
J.C
DrawFun wrote:Hello,
Cheers,
DrawFun
Where can we find this?
System – Windows 11
ChrisH
Hi
I might be wrong, but I think the setting is in the Add-On Preferences (go to the User Preferences (Ctrl+Alt+U in 2.79) > Addons and search for Octane).
You might want to deselect "Relative Path" in the left panel in the "Open Path" window (otherwise it will be relative to each .blend) (Also, remember to Save User Settings! ;D )
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Octane Prime - Blender Plugin user
Metal IOR values for Octane (with .blend library): https://chris.hindefjord.se/resources/rgb-ior-metals/
J.C
ChrisH wrote:Hi
The setting is in the Add-On Preferences (go to the User Preferences (Ctrl+Alt+U in 2.79) > Addons and search for Octane).
This is local database path for storing materials if I'm not mistaken.
System – Windows 11
ChrisH
You're right, I was mistaken, I'm sorry.
Reading the "Release notes" again it seems that it uses Blenders Temp directory (under File in User Preferences).
This seems to be corroborated by the fact that there's an "alembic_export.orbx" file in that directory after I exported an ORBX.
linograndiotoy
ChrisH wrote:You're right, I was mistaken, I'm sorry.
Confirmed, just as reported in the Release note.
J.C
There is still no option to disable this. Other plugins and standalone have this possibility.
System – Windows 11
linograndiotoy
We're going to add this option as soon as possible.
Return to “Blender”
