Cinema 4D Wont Start WIth Octane 4.02.1R3 [FIXED]
IOStudios
Note: This is probably the wrong place for this post, but for some reason I am unable to post in the official support forum for C4D Octane.
So basically the problem I am having is that, when I start Cinema 4D, Octane tells me about this new update available "Version 4.02.1", but when I go and download it, and install it into my plugins folder, Cinema 4D refuses to start, like it loads and shows the GUI, but has a spinning blue circle, and won't let me click anywhere, task manager says it's not responding. Version 4.01.1 and below works flawlessly with no issues. I tried to troubleshoot, but since Cinema 4D doesn't even start, I can't really do anything. :cry:
*It's not that this update is important to me, but I don't want this happening with future updates that enable vectron/spectron.
*I tried version 2018.1 which also resulted in the same issue.
System Specs:
Windows 10, Latest version
GTX 1070 + RTX 2070 (Strange combo I know but it works)
Threadrippper 1920X
32GB DDR4 3000MHz
500GB Samsung NVme + 2TB Barracuda HDD
Thanks so much to anyone who can help! :D
1600 Watt PSU
*Edit: If anyone else has this issue, I would update to R20 or atleast completely reinstall your current version of Cinema 4D, it seemed to work for me :)
which Nvidia drivers have you installed?
Please, go to c4d menu Script/Console, (Shift+F10), and share a complete screenshot of the panel, thanks.
ciao Beppe
IOStudios
Hey, thanks for the quick response.
I am currently on nVidia driver 417.71.
Also none of my GPUs are overclocked, just the CPU which is very moderate and has been stable for 4 months. with no issues.
Here is a screenshot of my console window with the working version of octane (4.01.1) since C4D won't start with the newer one.
please use DDU to completely remove the installed drivers:
http://www.guru3d.com/files-details/dis ... nload.html
Then perform a clean installation of 419.35 drivers:
https://www.nvidia.com/Download/driverR ... 4363/en-us)
Looking forward for your feedback,
IOStudios
So I used DDU to completely clear my drivers, and then I tried to install new ones from the link you sent however, it said "Not compatible with this version of windows". It told me that I should install Gforce Experience to get drivers that would work. I installed Geforce Experience and through that I was able to successfully install 419.35
Unfortunately Cinema 4D still refuses to load properly with Octane 4.02.1 and above :/
I feel like it might be a compatibility issue of some kind, I tried removing all my plugins and just leaving c4doctane, but that didn't change anything, my C4D version is: R19.068 if that helps.
Best regards,
Aspen
IOStudios wrote:So I used DDU to completely clear my drivers, and then I tried to install new ones from the link you sent however, it said "Not compatible with this version of windows". It told me that I should install Gforce Experience to get drivers that would work. I installed Geforce Experience and through that I was able to successfully install 419.35
Best regards,
Aspen
Post a screenshot of console window and c4doctanelog.txt too
IOStudios
Best regards,
Aspen
Where do I find c4doctanelog.txt?
Here is a screenshot of my console on the version of octane that works (I can't get to the console on 4.02.1 since C4D doesn't even start properly)
IOStudios wrote: Where do I find c4doctanelog.txt?
Have you deleted other plugin files as I described in release topic or readme.txt?
IOStudios
I just tried removing all plugins except c4doctane, Cinema 4D is still frozen.
IOStudios
Thanks to everyone who tried to help, I ended up fixing the issue on my own by completely clearing Cinema 4D R19, and just updating to R20. :D
Return to “OctaneVR Questions & Discussion”
