XParticles / VR Render Problem
pierresecondi
Hello !
I'm trying to render a scene using XParticles with an Octane VR Camera in Stereo and it doesn't work, there is some weird things happening (see render below).
I've tried many render settings, with and without caching the particles and I'm stuck...
Does anyone have an idea ?
Thanks !
Cinema 4D R20.057
Octane Render for C4D 4.02.1-R3
GTX 1080 Ti x2
There's not any different for stereo or normal rendering for particles and caching. It's still one frame. I think it's a different issue.
pierresecondi
Yes, it's a different issue because i've tried with a classic camera and I have the same problems...
It's a really simple scene with particles emitting from an object and follow its surface with trails...
I have tried to rebuild my scene from scratch in a new project but it doesn't work...
I don't understand what i'm doing wrong :cry:
Cinema 4D R20.057
GTX 1080 Ti x2
pierresecondi
aoktar wrote:There's not any different for stereo or normal rendering for particles and caching. It's still one frame. I think it's a different issue.
OK it seems to come from the "render as hair" in the octane object tag because i've tried using a spline mesher and the render is working (see render below)
But it inscrease drastically the render time per frame...
Any idea why the "render as hair" do that ?
Cinema 4D R20.057
GTX 1080 Ti x2
pierresecondi
It definitely comes from the hair render.
I've tried using the octane object tag on the xp-trail object but it doesn't work.
I've tried using the hair object with the xp-trail object as link but it doesn't work either.
I always have these weird artifacts or glitches when I render the scene...
Here is attached my c4d file..
Please HELP ! :shock: :D
Cuisine.zip
(113.33 KiB) Downloaded 145 times
Cinema 4D R20.057
GTX 1080 Ti x2
Hallsworth
So glad I've seen others are having this problem and it's not just me, been hitting my head against a wall thinking I was doing something wrong.
Same problem, trying to render xpTrail object with either an Octane Object Tag, or with the Hair Object and both are causing these odd glitches, identical to yours, and regular crashes.
Seems Hair rendering is broken in v4.02.1-R3 (and R2, haven't tried any others).
Win 11 64 | Geforce RTX 3090 x 2 | 3960X Threadripper | 256GB RAM
danielmzhang
Was this ever resolved? Currently having problems rendering hair with XpTrails. Getting glitches + artifacting similar to original post. Eventually just crashing out.
Works with xpSplineMesher.
Running
C4D R20.059
Octane v4.05-R5
X-Particles Build 732
