Cinema 4D version 4.02.1-R3 (Obsolete stable)
SRCOBB wrote:yes. R20.057
It's really doing it a lot, just putting the wrong materials on random things..
Could you try this updated builds?
https://render.otoy.com/customerdownloa ... Macosx.zip
https://render.otoy.com/customerdownloa ... R5-win.rar
Silverwing
Hi Ahmet,
I noticed that in the Octane Universal Material the coating roughens is not accessible via texture.
So the pin is missing on the Universal Material Node where you can plug it in.
And in the 2018 version there are further additions that are missing as:
Coating Roughness
Coating Bump
Coating Normal
Thanks for your time reading this and hopefully fixing it :-)
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
adamfilip
Running R3, Noticed that Camera and Frontal projection mapping is not working. texture does not show at all.
anyone else having this issue?
lancemoody
For me in R20, NVidia 419.35 not drawing the full UI:
Try with older Driver or plugin.
Kalua
adamfilip wrote:with R4 im finding its breaking and switching texture links.. I had to revert back to R3
So i apply one texture and another shows up
Same happening to me in R18 and V4 R5.
Leaf shader in place of the concrete shader... very weird.
This is showing in Live viewer window... in object manager the shaders are correctly assigned.
EDIT: I reverted to V4 R3 and problem is fixed.
Octane User since V1 Beta
SRCOBB
R5 - when I add a scatter object, it's crashing C4d and then my whole system.
C4D R20.057 OSX 10.13.6
Could you please mind a sample scene with me?
SRCOBB wrote:R5 - when I add a scatter object, it's crashing C4d and then my whole system.
It may not be specific to R5. Please test it with R3.
SRCOBB
Works fine in R3.
Return to “Releases”
