VDB Animation
chanson78
I have made a VDB animation from Houdini, output it with the smoke_$F4.vdb file name, which gave me a sequence of smoke_0001.vdb, smoke_0002.vdb, smoke_0003.vdb, etc.. The sequence goes all the way to 0079. When I try opening the animation via the Octane Volume object, I load the first frame of the vdb sequence under File, then Start 0 and End 79 but then it says VDB: Not Found!. What am I doing wrong here?
Cinema 4D R18
Octane 3.05.3
underworldtr
Increase the number in "digits" field.
C4D r18.048 / Octane Render Plug-in 3.06 / Turbulence FD (Build 1425) / X Particles 3.5
Titan X & GTX 1080
Win 7 Ultimate
chanson78
underworldtr wrote:Increase the number in "digits" field.
Nah, that didn't do anything.
crollalowis
I have the same Problem
crollalowis wrote:I have the same Problem
Could you please give a better data if you try it enough and still need a help?
crollalowis
Thanks so much, it works.
Amazing :D :D :D :D :D
