OctaneRender for Maya 4.02.1-13.34 [OBSOLETE]
Moderator: JimStar
Locked
JimStar
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya® Version 4
Maya® Version Requirements
This release will work with Maya® Versions 2016, 2016.5, 2017 and 2018 64-bit on Windows, Linux and OSX operating systems.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
  1. Go to https://home.otoy.com/render/octane-render/purchase/
  2. Select "Upgrade" in the top menu.
  3. Click on "UPGRADE NOW" next to "Upgrade existing licenses to OctaneRender 4".
  4. Select the licenses you want to upgrade and confirm.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changelog and the installers for Octane Standalone 4.02.1 are here:
OctaneRender Standalone 4.02.1
Please read the new features implemented from Octane Standalone 4 version our blog post.
Changes since version 13.33:
  • Fixed wrong camera FOV after export happened in some cases.
  • Workaround for Octane SDK issue: lost referenced file-resource in some cases for alembic nodes inside imported ORBX. Now alembic nodes will always reference the resource inside the initial ORBX, ignoring the "unpack resources" setting (before this is fixed in Octane engine).
Windows DOWNLOAD
OctaneRender for Maya 4.02.1-13.34 Demo
Linux DOWNLOAD
MacOS DOWNLOAD
Subscription Studio Downloads
OctaneRender for Maya Studio 4.02.1-13.34 [Windows]
OctaneRender for Maya Studio 4.02.1-13.34 [Linux]
OctaneRender for Maya Studio 4.02.1-13.34 [MacOS]
Jolbertoquini
Hi Jim,
For this fix is not really there "Fixed wrong camera FOV after export happened in some cases." basically you are supporting Vertical now but not Horizontal anymore, or any of the other modes. I think need be quick fixed because is completely off the viewport preview specially with the "Demo plug" the Licensed version is kind working the position of objects match but not export and preview ratio
I checked with Maya Viewport, Arnold, and other all Good I think is something necessary to be supported right for workflows.
Thanks to check on this Jim,
Cheers,
JO
here some screen shots:
P_V_Demo
P_V_Demo
P_O_Demo
P_O_Demo
P_H_Demo
P_H_Demo
P_Fill_Demo
P_Fill_Demo
L_V_Demo
L_V_Demo
L_O_Demo
L_O_Demo
L_H_Demo
L_H_Demo
L_fill_Demo
L_fill_Demo
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Jolbertoquini
Hi Jim,
I also realize the Vertical is working in any ratio so basically you can just adapt on any option to be interpreted as "Vertical" so would work for all other modes then horizontal.
We realize specially the fill is equal as vertical which is working on the licensed plug the demo plug is off.
Cheers,
JO
Locked
Return to “Releases”
