Blend material isnt saving correctly to the Local DB
Studio21
HI,
trying to save and restore blend material to and from the local DB seem to be broken.
textures are missing when loading saved blend materials and Universal sub materials are reverting to diffuse when loaded. can this be fixed?
Thx,
G
Saving is correct. But problem is in converting operation. There's only a missing part for diffuse slot on creation the nodes. And also convert operation is missing for a few texture types. Note that blend material's saving/loading operation to livedb is a hacked way. Because blend material is not a native type of Octane. Also you can easily store your blend materials in content browser. It was not possible with mix materials.
TonyBoy
So is it better to store Blends in the Content Browser instead of the Local DB?
TonyBoy wrote:So is it better to store Blends in the Content Browser instead of the Local DB?
You can use both but CB is better surely.
Studio21
thx for the improvements in 2018.1 RC 4 ahmet :)
there is still a problem though...there is an error loading the textures themselves after restoring a blend from the local DB
THX
G
Studio21 wrote:thx for the improvements in 2018.1 RC 4 ahmet :)
THX
G
Could you be more spesific? I fixed the problems as I could see.
Studio21
hi ahmet, this is whats happening:
blend when created
blend when created
and after restored from the local db
Test Blend.zip
can u test this orbx?
(1.62 MiB) Downloaded 207 times
Are you using it in a saved scene or untitled one?
Studio21
thx ahamet! was just checking on a saved doc and textures are restored correctly :)
its almost perfect...only thing that isnt restored now it seems is the sub material name...hopfully u can fix it as well :)
have a great weekend,
G
