Cinema 4D version 2018.1-RC1 (Test version)
Ron
Hi Ahmet,
this version crashes immediately when adding new nodes to NE if material uses subtstance shader.
Attached is bug-report and log-file.
Cheers - Ron
_BugReport.txt
Bug-Report
(515.41 KiB) Downloaded 410 times
c4doctanelog.txt
Log-File
(77.48 KiB) Downloaded 365 times
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
Ron wrote:Hi Ahmet,
Cheers - Ron
_BugReport.txt
c4doctanelog.txt
Could u send me a scene?
desire
Every render via RenderLayer feature with Black Shadows pass (since v4), gives this result in object's shadow:
bagel
desire wrote:Every render via RenderLayer feature with Black Shadows pass (since v4), gives this result in object's shadow:
I use this feature all the time. I don't have this problem with RC1. What are your sample settings like?
Hi desire,
here is working as expected, do you have an HDRI Environment without Importance Sampling active?
ciao Beppe
natemac00
Any timeline when we might see a build with Volumetric lighting?
______________
Nate Mac - Chicago, IL
Cinema 4D R26.107 | Octane 2021.1.6
Main: AMD ThreadRipper | Win10 | 32-core | 128GB | RTX A5000 & GTX 2070 SUPER
Slaves: 4x GTX 980 Ti | GTX 1080 | GTX 1070 | GTX 1070Ti
desire
bepeg4d, that's no matter what type of light source is used...
bagel, i understand what you mean, but any samples count gives no difference in shadow noise
Here is one more render sample - 1 light source (arealight) , 900 samples
KeeWe
Just a quick question: Where do I find the installer for the network daemon?
Edit: Is there some sort of manual for the crypto matte feature? Using EXR(Octane) and ticking CryptoMaterial and CryptoObject doesn't work as expected on Objects with Object Tag and different materials.
Ahmet, maybe you could provide a sample scene?
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
Return to “Releases”
