Does anyone have the same issues, and how to fix that? I don't want to waste my money
ERROR "TCP PORT 5130 & 5131" ON OCTANE SERVER STUDIO & VR.
- lachizung1206
Hello everyone. I can not open Octane Server Studio and VR. Before buying the license, i have already instaled Octane 4.0 Demo version and every was working fine on my laptop. After instalation purchared versions, there were some errors appeared like "TCP Port 5130"; "TCP Port 5131" and "Authentication did not succeed from using TCP Port 443"
Make sure that there's no process of OctaneServer running (it might be, even if there's icon in the notification field [lower right], especially if Octane server crashed etc) in the Task Manager, if there is, kill it.
If that doesn't work, you can open PowerShell and run or to see what process is using those ports.
As for the last image, make sure that if you're using a proxy that those settings are correct, or disable/not set if your not using a proxy.
Also make sure that Defender, or any other Firewall isn't blocking Octane.
Get-Process -Id (Get-NetTCPConnection -LocalPort 5130).OwningProcessCode: Select all
Get-Process -Id (Get-NetTCPConnection -LocalPort 5131).OwningProcessAs for the last image, make sure that if you're using a proxy that those settings are correct, or disable/not set if your not using a proxy.
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Octane Prime - Blender Plugin user
Metal IOR values for Octane (with .blend library): https://chris.hindefjord.se/resources/rgb-ior-metals/
- rondomingue
I'm getting the same error as well and when I run the script above it shows that I'm currently running an Octane Server. How do I either disable it or switch to the correct server?
- rondomingue
I see the that Octane Server is running in the PowerShell. How do I deactivate it to run the Octane Server for Blender?
Handles NPM(K) PM(K) WS(K) CPU(s) Id SI ProcessName
167 14 141576 43216 0.44 10728 1 OctaneServer
