phoenix particles cuda 719
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
coilbook
This is what happens when rendering phoenix particles with LIGHT EMISSION and AI light enabled. There is a bug with ai light and large amount of glowing phoenix particles.
c:\jenkins3\workspace\max_plugin_release_windows\src\externalpluginsupport\octphoenix.cpp(616): func<PhoenixFDSupport::ophGetParticleGroupUID_FromName>: , Assertion type WARNING: condition "0" failed, <Failed to find PhoenixFD particle group name <Particles of Time machine01> in octane configuration file!
Please edit octane3dsMaxConfig.cfg..>
CUDA error 719 on device 1: unspecified launch failure
-> kernel execution failed(kernel52)
device 1: failed to update AI light
-> failed to copy memory to device.
-> failed to launch kernel(kernel63)
-> failed to load symbol data to the device(kernel data)
device 1: direct light kernel failed
CUDA error 719 on device 2: unspecified launch failure
device 2: failed to update AI light
device 2: direct light kernel failed
denoiserThread1 : Exited with a error. Restart required
-> failed to unregister pinned memory
-> could not get memory info
-> failed to destroy CUDA event
-> failed to deallocate device memory
-> failed to deallocate pinned memory
-> failed to deallocate device array
-> failed to unload module
-> failed to bind device to current thread
device 1: failed to initialize context
device 2: failed to initialize context
denoiserThread1 : Initialization failed. Restart required
CUDA error 201 on device 1: invalid device context
-> failed to create link
device 1: failed to create OSL compile context:
device 1: failed to compile module 0
CUDA error 201 on device 2: invalid device context
device 2: failed to create OSL compile context:
device 2: failed to compile module 0
paride4331
Hi coilbook,
did you update the Nvidia drivers? NVIDIA 418.81 driver (Feb. 4th) doesn't work with Octane
In this case install 417.71 Nvidia drivers. To get an effective Nvidia drivers installed, please use DDU Nvidia unistaller drivers, the best way to get a clean installation.
http://www.guru3d.com/files-details/dis ... nload.html
Let me hear from you.
Return to “Bug Reports”
